1 hour ago, Picasso said:
The thing is you replaced it been OK now not not staring again this tells me you probably blown the fuse again but what's causing to blow I would check the fuse again and get the starter motor checked
Have you got a part number for the brown relay ?
  • Replies 53
  • Views 10.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • start relay fuse is located behind passenger glove box I have attached drawings from lookup system circled in red hope this helps location is 2
  • Thank you everyone for your help, the love bus is up and running again. It all down to a relay in the passenger footwell
  • Fuse is 7.5A.
Posted Images
On 8/8/2023 at 3:43 PM, Rojie said:
 Your model is the Gen 1, pre-face lift version.
Mine is the post face lift version.
The JPNZ Owners Handbook definitely states fuse 10 in the fuse box by the drivers seat.
Does the fuse box you have have 10 fuses, no more ?
My model is an MZ G Edition; so your seats are probably not the same as mine.
I'm sorry I cannot help further.
Mine is mnh15 I think it's the 3.0L AWD one.
I'm currently trying to find an ignition barrel, all my fuses are fine only other thing I can think of is changing all the relays
I think you need a more methodical approach rather just changing parts. Use a multimeter to check the voltages are correct at the correct points when you try to crank. We have access to the wiring diagrams albeit with Japanese annotations.
