Alphie Posted August 13, 2023 Posted August 13, 2023 Hi. The ride height / ground clearance of my conversion (with no extra load added) has always been quite poor, causing regular grounding in camping fields. I have noticed (at the club meet) that it sits a good inch or two lower than most other vans. My question is, has anyone sought to improve a situation like this with new or uprated rear springs? Thanks Chris.
Picasso Posted August 13, 2023 Posted August 13, 2023 Hello Chris do you know if your van has been lowered such as has it got coil overs
Alphie Posted August 13, 2023 Author Posted August 13, 2023 2 hours ago, Picasso said: Hello Chris do you know if your van has been lowered such as has it got coil overs It seems to have original looking plain (single) coil springs (i don't know what 'coil overs' are however) and I know it hasn't been lowered since import and conversion (4 years ago). I've always just accepted that its down to the extra weight of conversion but now I've seen other camper versions I can see there is a difference. thanks for your reply Lee.
Picasso Posted August 13, 2023 Posted August 13, 2023 Well the option is to go for heavy duty springs these are standard height to the originals but give a harder ride so for you these should alter hight and carry the extra weight better
Mick Mc Posted Thursday at 01:05 PM Posted Thursday at 01:05 PM hi there how did you get on with getting new springs I want to uprate the ones on my vellfire camper if I can find the size and dimensions of them I might be able to use helper springs (springs that go inside the original ) to make them stiffer but at the moment the company doesn’t do them but they might have them just made for a different model of car
