Help needed - could do with some technical help retro fitting cruise control on my ANH20.
Have fitted the stalk (2 wires) and it doesn’t work, no green light. Road tested over 40mph and nothing. Checked the wiring to the switch and seems to be getting voltage etc.. fitted new switch still same. Checked operation of switch and seems to be working okay. Removed speedo head CAN converter still no joy?
Any other thoughts which I may have missed?
Thanks in advance 😁
Just an update on the above post, took the Alphard on a long camping journey and found that the cruise control was working. Few points to note for anyone else considering the upgrade.
  • Green light on dash doesn't work "CRUISE" symbol to show if ON or OFF
  • When using you have to first hold the On/Off button in for a few seconds to turn it On
  • When using the stalk also have to hold for a few seconds before any response
  • Works below 40MPH which was a surprise considering some other posts I have read
Good upgrade once you get to know how it works correctly 😁
I have just fitted the cruise stalk and everything worked including the dash symbol so really happy. I have modified the stalk cover but am looking for a OEM one from a factory fitted cruise stalk but can not locate one anywhere, anyone any ideas?
Send a Private Message to Picasso with your registration
Look for cruise control cutout panel on eBay just look under Toyota not Alpharetta.
