Hi all,
I put this in the Title Topic for your attention  - But its connected to the subject and thread below and my most recent coment on it.
Engine or Inverter? Car wont start!
Hope thats ok?
Best
David
Have you changed your car battery reason for asking you got a fuse link on positive of battery you may have blown it this is the main fuse check that first
Which Batt? The 12v or the hybrid?
I havent changed the 12v batt. It was fine as far as I know before the car stopped. Batt only 2 years old. Although, it is now flat as the car has been sitting there for 4 months. Have trickle charged it a few times but has stopped holding charge now as gone below 7%.
Wouldnt that have come up on the Diagnostics?
Would it have affected the Inverter or caused a P3125 -  Sub codes 495,496,497 and 484?
Is it worth buying a new battery first - I need a new one now anyway!
A bad 12v battery will stop the hybrid system from working- happened to me and the correct replacement is not cheap. It is a good starting point.
