Hi - I've seen an Alphard for sale but it looks like its sitting low. It's had a home conversion and I'm wondering if it's the weight on the springs?
Are there any checks I could do?
Hello Mark,
Private Sale or Business Seller ?
Check the wheels and tyres are the correct size. Are they 16 or 17inch ?
205/65/16 or 225/55/17.
Check the minimum ground clearance, 160mm.
Is it a rear conversion or a side conversion ?
Quality of conversion ? Gas integrity, if fitted ?
Either way, IMHO, it is unlikely to be the additional weight.
Most conversion involve removing the middle and rearmost seats.
Many Alphies are lowered, either in Japan or the UK. Ground clearance can become an issue.
Replacing suspension parts (excluding wheels and tyres) to revert to factory will cost upwards of 1200 !
AA RAC Inspection may be advisable. Mine cost 300 pounds, and was very reassuring.
Other than that, all the usual precautions when buying a pre owned vehicle.
Check the undersealing too.
Is the speedo in miles or kilometres ?
Insist on a copy of the Auction Sheet BEFORE you part with any cash.
Good Luck.
Thanks for the responses. Very useful
2 hours ago, Rojie said:
Hello Mark,
Good Luck.
Thanks. The ground clearance is =< 150mm so it looks like it's been lowered. Would that be a red flag?
And are the wheels and tyres standard sizes.
IMHO, only an opinion, I would not have thought 1 cm would not make much difference.
These machines do have a soft ride so it can be difficult to assess whether the springs are worn.
You don't say whether the conversion is side or rear ?
Hi - sorry, yes,  it's looks like a home done rear conversion and the tyres are 205/65 R16. 160 cm is around 6.3 Inches so, yeah, just over a cm!
It is quite normal for the front valance to be lower than the rear valance.
Private or Business seller ?
Private
Hi, mine has lowered uprated springs with 18" alloys, always wary of flooring but have not yet had a problem. Ride is brilliant!
nice photo, lowered vehicle with skinny depth wheels definately a no no if your considering camping  in some of the awlfull 'field type' campsite's in the UK
Had no problems yet but am very wary, helps with 4 wheel drive though.
Not interested in winter camping.
7 minutes ago, Picasso said:
thats got coil overs all round nice vehicle
How can you tell??
i can tell by the photo its lowered there is no clearace between the wheel arch and top of tyre on the shocks should be a round what looks like a nut you can manually adjust the hight of each shock high or low but wont make much difference to be honest with you i would personaly put it back to standard suspension cost is about £1200 in parts i had mine done when i bought mine as it was lowered and to many speed bumps and pot holes where i live.
Thanks. The photo is of someone else's Alphard, not the one I'm considering.
To be clear i've fitted coilovers to several racing touring cars when situated at Brands Hatch in kent ..they are not designed for the alphard type vehicle ,, they are designed t to be a
repacement adjustable coil/spring suspension for the standard suspension of saloon cars and single seater race cars
  • 8 months later...
I have same green coil cover and my new alphard is very low. Front bumper has ground clearance of less than 10cm I think. I suggestions where to take this car for normal coil adjustment? I live in london.
Hi, just measured mine at 15cm, yours must be super low. I haven’t had any problems grounding yet. 😬
15 cm is normal.
Indeed, mine is just 10cm..
