I was trying to install a back up cam, jammed a wire from reverse light. After all the wiring the following problems appear,
1. reverse lights don’t work
2. Shift indicator not working
3. Central doors lock would not unlock when i put to P
4. alternator has zero output( checked by a mechanic, he said usually has low output even it’s dead.
Driving is no problem. Transmission still doing right. Anyone know if i has shorted some wiring or just the alternator problem?
Hoping anyone can help!
A long distance Hello to Bruno,
Hi Rojie!
Where were you jamming the wire ?
I was trying to use the existing wire which is a 4 pins plug, tested a bit and can't get any video signal and given up using it.
Finally put a new wiring and have it jammed to one of the reverse light to get 12v power and reverse signal.
