Buzzi Posted November 1, 2023 Posted November 1, 2023 Hey, our powered automatic doors of our ATH10 Alphard Hybrid is struggling since a while with opening the side doors and the tailgate. Is there somewhere a service protocol tutorial where to grease them? I have blamed it so far on the weak starter battery, but after we've replaced it the issue still persists. The issues in detail: the side doors needs a little jerk to start opening. Shutting works fine the back tailgate door doesn't open at all and closing the door stops after 10-20cm and stops at a resistant and goes up again. Thanks!
pipsyp Posted November 2, 2023 Posted November 2, 2023 Not the 12v battery starting to let go is it? Does it turn over Ok?
Rojie Posted November 2, 2023 Posted November 2, 2023 23 hours ago, Buzzi said: Hey, our powered automatic doors of our ATH10 Alphard Hybrid is struggling since a while with opening the side doors and the tailgate. Is there somewhere a service protocol tutorial where to grease them? I have blamed it so far on the weak starter battery, but after we've replaced it the issue still persists. The issues in detail: the side doors needs a little jerk to start opening. Shutting works fine the back tailgate door doesn't open at all and closing the door stops after 10-20cm and stops at a resistant and goes up again. Thanks! Sorry for this silly question. Are your doors and tailgate powered ? I assume they are. Does the tail gate fail to open with the internal switch, the remote switch, or both ? Same question with closing ? If using a remote for the tailgate, hold the button for several seconds.
Buzzi Posted November 2, 2023 Author Posted November 2, 2023 2 hours ago, Rojie said: Sorry for this silly question. Are your doors and tailgate powered ? I assume they are. Does the tail gate fail to open with the internal switch, the remote switch, or both ? Same question with closing ? If using a remote for the tailgate, hold the button for several seconds. Wow, that's awesome. The trick pressing the remote button for a few seconds made it, incredible. It's opening and shutting without issues. I'm very impressed, thank you so much Roger! Is this a kind of reset or what made this? The two side doors need a bit of encouragement holding the handle a few seconds for opening and shutting. The buttons on the dashboard only cause a beeping and a brief jerk when pressing.
Rojie Posted November 3, 2023 Posted November 3, 2023 9 hours ago, Buzzi said: Wow, that's awesome. The trick pressing the remote button for a few seconds made it, incredible. It's opening and shutting without issues. I'm very impressed, thank you so much Roger! Is this a kind of reset or what made this? The two side doors need a bit of encouragement holding the handle a few seconds for opening and shutting. The buttons on the dashboard only cause a beeping and a brief jerk when pressing. I think the delay is to help prevent inadvertent opening. I cannot help on the sliding doors other than to say the cable system can get 'tight' with age. Increased friction can be enough to cause issues. But it may not be the cabling. Search this forum for Sliding Doors , or similar. It is not unusual for door issues to occur. Many members have fixed their problems themselves. When opening the slide doors the handle does does need a second or two to respond. I know you have a new starter battery; make sure you keep it fully charged or little Gremlins can occur in the electrics. 1
Buzzi Posted November 6, 2023 Author Posted November 6, 2023 Hey Rojie, thanks again. It still works very well. Is there a way to grease the backdoor? There are still some squeeking noises to hear, but I'm not sure if that really comes from the stuts.
Rojie Posted November 6, 2023 Posted November 6, 2023 2 minutes ago, Buzzi said: Hey Rojie, thanks again. It still works very well. Is there a way to grease the backdoor? There are still some squeeking noises to hear, but I'm not sure if that really comes from the stuts. If your struts are making squeaking noises they may be on their way out. Are the rods very smooth ? I have lubricated my struts with fine oil to improve the smoothness of operation; but it made no noticeable difference ! I also greased the tail gate pivot points with auto grease ( the type used for the door hinges). It may little difference, my tailgate is not as smooth as I would like. Toyota quoted me 200 UKP each for the struts. I have not yet made the plunge as it may be the tailgate motor needs an overhaul ! I have a rear conversion which makes access to the motor rather tricky. Get yourself an Owners Manual, they are published by JPNZ.
Buzzi Posted November 13, 2023 Author Posted November 13, 2023 Hey Rojie, I was just too impatient. I have used dry lubricant spray on the stuts. It just took a couple of days until it worked again very smoothly. Thanks again!
Rojie Posted November 14, 2023 Posted November 14, 2023 10 hours ago, Buzzi said: Hey Rojie, I was just too impatient. I have used dry lubricant spray on the struts. It just took a couple of days until it worked again very smoothly. Thanks again! Can you please provide details of the 'dry lubricant' you used siuccessfully ?
Buzzi Posted November 14, 2023 Author Posted November 14, 2023 14 hours ago, Rojie said: Can you please provide details of the 'dry lubricant' you used siuccessfully ? Sure https://wd40.co.uk/product/anti-friction-dry-ptfe-lubricant-spray/
Rojie Posted November 15, 2023 Posted November 15, 2023 9 hours ago, Buzzi said: Sure https://wd40.co.uk/product/anti-friction-dry-ptfe-lubricant-spray/ Thank you very much. I'll get some and give it a try. 1
