First time I have been out in my Alph when it’s been cold - turned on the fan and turned temp up - rear heating is working , but front will only blow cold air . Anyone able to help me resolve the problem
cheers
cheers
Hello Chad,
Another member recently started a thread on this subject.
The search box is on your home page at the top right corner.
The search function doesn't seem to work very well for me. i put in HEATER in the box, and all i get is this thread....
Hi, I had  what i thought was a problem a little similar in that the front wasnt getting /staying warm on a slightly longer trip.
i left the expansion tank top off while parked idelling   for a while incase of airlock.
i took what was easy to remove  around lower centre consul to check blend actuator and that was working fine.
I think the problem for me was just stuff in the back piled up around rear vents under seats that  seemed to  shut off the front heat
Now its colder might check again
Cheers 👍
