Diran Posted January 29 Posted January 29 Good morning, We are looking for a used or new Alphard 3.0litre engine for my car. Please, where can we get the engine as we have looked everywhere to no avail. Regards Diran
Geralt Posted January 29 Posted January 29 Here's one in Derby: https://www.ebay.co.uk/itm/255894296120 Try @Picasso He's local so may be able to help.
Rojie Posted January 29 Posted January 29 3 hours ago, Diran said: Thank you very much. I will contact him When I checked Geralt's link above there were two more engines available, from different sources, at a lower cost. It will be important, if possible, to discover the history of any engine you are considering. A business seller should be able to offer a warranty.
Picasso Posted January 29 Posted January 29 i would personally have the original rebuilt whats wrong with your engine why you looking for a replacement
Diran Posted January 29 Author Posted January 29 1 hour ago, Rojie said: When I checked Geralt's link above there were two more engines available, from different sources, at a lower cost. It will be important, if possible, to discover the history of any engine you are considering. A business seller should be able to offer a warranty. 1 hour ago, Picasso said: i would personally have the original rebuilt whats wrong with your engine why you looking for a replacement 1 hour ago, Picasso said: i would personally have the original rebuilt whats wrong with your engine why you looking for a replacement Thank you Picasso. It was over heating and was told the gasket is gone.
Diran Posted January 29 Author Posted January 29 Thank you Picasso. It was over heating and was told the gasket is gone.
Rojie Posted January 29 Posted January 29 3 minutes ago, Diran said: Thank you Picasso. It was over heating and was told the gasket is gone. Which gasket ? If it is a head gasket there will probably be a milky substance in the oil filler cap. You will be getting water from the exhaust pipe and using a lot of water as a result. Explain what symptoms you are experiencing.
Diran Posted January 29 Author Posted January 29 There is a paste around the oil filler cap. And it drives slower especially when going uphill and start jacking when I stop the car.
Rojie Posted January 29 Posted January 29 1 minute ago, Diran said: There is a paste around the oil filler cap. And it drives slower especially when going uphill and start jacking when I stop the car. Sorry, but what does jacking when I stop the car mean ? Are you using water ? Any misfiring ?
Rojie Posted January 29 Posted January 29 1 minute ago, Diran said: I was told the head gasket is gone. What mileage has it covered ? Has it been over revved ?
Diran Posted January 29 Author Posted January 29 I mean juddering when stopping. It is misfiring as well. It has done about 114,000kms
Geralt Posted January 29 Posted January 29 Sounds like it is the head gasket. You don't need a new engine. You need the heads removing, check for warping and skimmed if so then reassembling. Any good garage would do that. 1
Diran Posted January 29 Author Posted January 29 I have taken it to few places but they won't touch it because it is an import. Do you know any garage that would do it ps?
Geralt Posted January 29 Posted January 29 Am confused. Who did you have in mind to change the engine then? If it helps, it's the same engine as Camry V6. If you get hold of a Haynes workshop manual that should be enough to persuade them to do the job.
Diran Posted January 29 Author Posted January 29 A garage in Birmingham but he told me I have to get another engine as he won't be able to repair the one there now.
Diran Posted January 29 Author Posted January 29 If someone can recommend a garage I can take it to I would really appreciate.
Diran Posted January 29 Author Posted January 29 I have tried Gibb but he said he doesn't do head gasket.
Geralt Posted January 29 Posted January 29 Try an engine rebuild specialist. https://crautoengineering.co.uk/about-us
Picasso Posted January 29 Posted January 29 If your in no rush to have it done and want a proper job doing and prepaired to wait contact. Contract mechanics the owner is Simon specialises in mazda bongos but does all imports he very busy person but you get a top job done he not far from Southam give him a call .
Rojie Posted January 29 Posted January 29 5 hours ago, Diran said: I have taken it to few places but they won't touch it because it is an import. Do you know any garage that would do it ps? Do you know which cylinder bank has the issue. From the front of the engine bay; is it the near bank or far bank ? This engine was also fitted to a Lexus. Try and find a qualified Toyota Master Technician who has worked on Camry and Lexus cars There is one in Bodmin; it might be worth giving him a call to see if he has any contacts near you. There must be someone capable in The Midlands. I'll find his name; I know it is a silly one ! DyerNostics, Toyota Specialist
