Kaleem Posted February 8, 2024 Posted February 8, 2024 (edited) Hi I am new to this forum I have Toyota Alphard ANH20 2009 and I want to install the factory OEM Roof Monitor in my Alphard it has roof fittings there just want to cut the hole in the roof and install it but the problem is I have installed the Kenwood Head unit in my Alphard and it has video out and I want to connect the screen to the Kenwood Head unit. I am searching on the internet if I can get the pinout diagram from net so I can power up the screen and figure out the video input wires and moter triger signal wire? Please help me out if anyone know the pinout. Thanks Edited February 8, 2024 by Kaleem Not enough details 1
Rojie Posted February 8, 2024 Posted February 8, 2024 10 hours ago, Kaleem said: Hi I am new to this forum I have Toyota Alphard ANH20 2009 and I want to install the factory OEM Roof Monitor in my Alphard it has roof fittings there just want to cut the hole in the roof and install it but the problem is I have installed the Kenwood Head unit in my Alphard and it has video out and I want to connect the screen to the Kenwood Head unit. I am searching on the internet if I can get the pinout diagram from net so I can power up the screen and figure out the video input wires and moter triger signal wire? Please help me out if anyone know the pinout. Thanks Hello Kaleem, Welcome to the Forum. 1
Pastafarian555 Posted February 9 Posted February 9 Hi Kaleem, I've just bought a Vellfire with the kenwood and want to know the exact same info as yourself. Hopefully someone in this forum will be able to help.
Chris.ac Posted February 12 Posted February 12 The Toyota rear screen uses ntsc, and it's quite low resolution. You may be better with an aftermarket rear screen. What type of video out is there on the Kenwood?
