Toyota Alphard ANH20 Roof Monitor Connector Pinout?
Hi I am new to this forum I have Toyota Alphard ANH20 2009 and I want to install the factory OEM Roof Monitor in my Alphard it has roof fittings there just want to cut the hole in the roof and install it but the problem is I have installed the Kenwood Head unit in my Alphard and it has video out and I want to connect the screen to the Kenwood Head unit. I am searching on the internet if I can get the pinout diagram from net so I can power up the screen and figure out the video input wires and moter triger signal wire? Please help me out if anyone know the pinout. ThanksIMG20240208153611.thumb.jpg.d731f4b395c7a21056991537e4b7861f.jpg
Edited by Kaleem
Not enough details
Hello Kaleem,
Hi Kaleem, I've just bought a Vellfire with the kenwood and want to know the exact same info as yourself.  Hopefully someone in this forum will be able to help.
The Toyota rear screen uses ntsc, and it's quite low resolution.
You may be better with an aftermarket rear screen.
What type of video out is there on the Kenwood?
