hi, me again.2 problems  .1 my 2005 alphi.2.4.have been on before about this.You have all been so helpful.a while ago i messaged that problem was oxegen sencer.renewed this with new sencer and coils and new spark plugs.All from Toyota.cost arm and a leg.Alphi running buitiful.After i go on run approx 60 to 80 mls up pops the dreaded light.Turn off egnition,then on again light has gone off.Drive again for 30mls and comes on again .cleared Air flow sencer.put cleaner in petrol tank on advice from members.Must add,i dont think my Alphi could drive any better than it is.My second problem is my wifes Honda Civic..1600 reg,2002.Same thing.Had this car from new,done 80,000 mls 22 years old.Drives great .Woul you beleive red engine warning lightstayes on al the time .Had full service 8 months ago new plugs etc,Plugged in my JP 700.exactly what it says  is
Pending,P0401.Exaust gas recirculation flow insufficient.Detected.This is the wierd thing.When i plug in my JP  700 into my Honda sivic it will only read out on the Toyota brand not at all on the Honda brand.Above is what it reads out exactly.Once again,thank you all in advance for any help.Kind regards to all.Phil.
Don't turn ignition off. Read the code while the light is illuminated.
Sounds odd but in this case it doesn't matter. The P code meaning is the same for any brand. The important things is that you've got the code.
I guess you need to remove the EGR valve, clean it and check again. If the code comes back you probably need to replace the valve.
Hi Geralt .Where would i find theGER VALVE.THANK YOU FOR YOUR HELP.
I don't know anything about Civics sorry. You're better off Googling for some pics or videos.
Try changing your secondary waterpump, for the inverter, that throws up all sorts of warnings. Did mine and rund great, also check out parts for a Lexus,  cheaper than Alfie parts, £100 saved on the o2 sensor.
