Blocked Drains...Sloshing Water Noise
Greetings owners..
I have sloshing water sound, which sounds like it's coming from behind the dashboard, I presume the drains are blocked and the water had nowhere to go. Can anyone advise " where " the drains are located and how to unblock the muck...
2004 Alphard converted camper..
Chris B
If you have a pop top (like a Drivelodge) might be water in the front spoiler section.
The sealant on mine has gone in a couple of places and does fill up in heavy rain, does exactly as you describe.  Bought some Sikaflex sealant to sort it (a job for the summer 👍)
I use a trim tool to lift a section where the sealant has split on the front to let the water out periodically, surprising how much gets in there!
If not, could well be blocked sunroof drains.
