Gear shift problem
Hi guys my alphard will not go into gear when engine is running but when I switch engine off and put ignition on and gently move the gear stick I can hear a electrical click like a relay coming from the steering rack area and can feel the click through the ignition key any ideas please
Does it exit Park with the shift lock release button pressed?
Yes it does and you can drive the car normally but when you put it back in park it locks again
The next easiest thing to check is the brake light switch. Are your brake lights coming on?
Yes brake lights coming on thanks for your help with this geralt
Then just the P/N switch, solenoid or something mechanical remains the issue.
Since you hear a click with ignition on and foot on brake, it could be the solenoid and P/N switch are OK but something mechanical is broken. If I were you I would remove the fascia and try to reach and examine it visually.
That's what I'm on with now but all looks well I'm 99% sure it's this clicking what the fault is in the steering colum must be a electrical fault as only clicks when ignition is on
I'll check tomorrow what I hear in my van.
Can you see what looks like a motor on the ignition barrel I think this is the problem
Great help thank you were can I order it
Why do you think it's the problem? I'm not following your logic here given the problem you face. If you can rotate the ignition barrel and start the car, then there's probably nothing wrong with it. Are you just wanting to replace a part that happens to click? A click is usually a good sign: A relay actuating or a solenoid moving.
If the problem really is the shifft lock solenoid (TBD), then this is the part 85431-58010:
https://www.amayama.com/en/part/toyota/8543158010
Not surpisingly it's attached to the gear shift lever, not the steering column.
That's great help thank you
As promised, I hear a click too coming from a similar area in my van. Whatever the click is (probably a relay), it is normal operation and is not the cause of your problem.
Great help once again thank you
Hi my Alphard when ramp up to 30-40 kmh the engine will drag if I increase speed slowly. If I ramp on it, it will get over the drag and speed up. May I know what's the problem. Thank you
Hello Adrian,
Please complete the details in your profile.
It helps us help you if we know what vehicle you have !
Age and type.
