Front door skirting removal
Hi, The passenger door skirt has come away from the door, I suspect one of the clips is broken. Does anyone know how to remove these panels and which clips id need to replace?
Hello Justin,
  • 6 months later...
Hi Justin - same thing here! What did you do to fix it?
  • 4 months later...
Hi, my door skirting started to come off when front wheel dropped into a large hole and tried to tow out.
Did you manage to find suitable fixings/clips?
Cheers, Roger
Hey mate. Ive got a local garage that I trust and they did it when I took it in for an mot. I couldn't find the right clips. They did, it took them ages to find and cost 16£ per clip! Came to something like 200 with virtually no labour as they felt bad charging me so much! Good luck - sorry not particularly helpful or good news!
Hi Did they say where they got the clips from? Thanks.
I need skirt clips and bumber clips 😩
Hey Diane - I will ask when Im next in the garage and let you know.
R
I’ve ordered fixings for my door skirting from my local Toyota dealer in Bromham, Beds. Can also be ordered on line from a Toyota dealership in Swindon.
Part numbers for
Alphard ANH10
Front door skirt fixings
parts numbers are
76932-58010
75397-58010
R
many thanks.
Part numbers for
Alphard ANH10
parts numbers are
76932-58010
75397-58010
many thanks I will try online
Collected parts today😊. Both types of fixings were £2.82 each plus VAT.
Please note the end fixing (top right hand side) on my vehicle is a retainer bolt part no. 76931). To undo access from other side of door via a large circular black grommet.
