Hi All,
Im sure its been talked about before, but any information or diagrams for installing a cruise control onto my 2003 3.0L Alphard G would be great!
Thanks lads!
2003 alphard will be very expensive as its not fly by wire 2005 onwards lot easier to fit cruise control be over a £1000 at least to do before 2005
There are universal cruise control kits available for around £300, but then there is the installation cost on top of it if you aren't able to do it yourself.
2 hours ago, grizzy said:
Hi All,
Thanks lads!
Hello Kevin,
50 minutes ago, Rojie said:
Hello Kevin,
Thanks, just purchased ours a couple days ago and we are very excited about it.
If anyone has any inclination about wiring diagrams that would be amazing to hand off to my mechanic.
As Lee pointed out; what you are trying to achieve is no simple task.
My advice, forget Cruise Control; you really should not need it with that V6 purring away.
Wiring diagram ?
As Lee states, cruise was not fitted prior to (late) 2005; so there is no wiring for it.
Gen 1 facelift yes, original Gen 1, no.
