Hi I recently bought an 03 Hybrid Import 2.4l petrol and I either need to replace or have the instrument cluster/speedo replaced or repaired. Any help would be appreciated. It would appear the lighting inside isn't working properly and the temp gauge has a mind of its own.
Thanks in advance
Thanks in advance
Hello David,
Behind the cluster you will find a speedo chip this a ck un09 these are fitted to change to mph if this has been fitted wrong such as fitted with wire connectors or electrical tape this will cause issues the are supposed to be soldered or chip could be faulty I would check this first before splashing out money
Thanks Picasso I'll have a look
