Aux input on headunit 2006 (56) Alphard 2.4
Hi Roger, found the brightness sliders today, both set in the middle, as you said, it is better but not greatest in bright sunlight as today
Edit, have ordered an english language owners manual/handbook from Amazon, and a GPS speedometer, importer has converte KMH to mph, but it is reading well above actual speed
Edited by rallychief
If your wheels and tyre combination are NOT to OEM sizes your speedo and odometer will be inaccurate.
Try willtheyfit, or something similar, as you can check errors 'magnitude' with non-standard tyre wheel combinations.
Thanks Roger, it has factory wheels, i have the GPS speedometer now, and it pretty much agrees with the speedo on the Alphard, so i think the GPS speed readout i was using which is part of MY Digtal OS mapping ( Memory Map )to check the Alphard, is actually not to accurate. fortunately the GPS speedo i bought has other functions, ie clock, compass overspeed warning, trip mileage and prob others i haven't found yet
One other niggle is the fairly constant chatter from a female Japanese voice, and the constant beeping, can either of these be turned off or disconnected
I think in Toyota Techstream you can turn off beeps, or at least change them.
Techstream is free, but you will need the correct cables.
Search the Forum for tips on which cables to buy.
I thought the Japanese lady was turned off via the stereo menus?  There isn't much that can be customised via techstream for the Gen 1.
Any ideas how to turn off the ladys voice in stereo menus, it's the more irritating of the 2 issues
Quick update, the dealer has now fitted this box, it is just a generic Android/Apple Car Play box, it expands the radio, but still has the japanese Frequency range 76-90 so you have no idea what actual frequency you have, its a guess to what programme you have, it's also impossible to navigate, it works through the TV button, so i have lost my Aux input, all in all a disaster
  • 4 months later...
On 6/19/2024 at 4:54 PM, rallychief said:
Hi Roger, here is a pic of the whatever with disc slot inside the centre console, played with all the buttons today and rolled the screen out, inside their seems to be 2 slots cd and poss mini disc, and their is touchscreen option for MD, found the setting for the hard drive, it has one, and their is music on it, is their any way of brightening the screen up, camera screens are very dim, re radio the dealer as part of the package, fits a box which is £350 which does all sorts of things usb input bluetooth hands free uk sat nav etc , but was out of stock be here this weekend let you know exactly what is when its in.
Cheers Chris
Hi Chris. That's for the etc card for Japanese motorways. Mine was in the cool box between the seats. I removed it as its unnecessary. I've just managed to connect my phone to the Bluetooth but it only seems to work with the phone app and doesn't connect to play music or anything else. I'd quite like to connect some rcd cables to the rear of the unit for audio input from my phone but from photos I've seen there doesn't seem to be any rcd connections in the back of the unit. Where did you plug in your rcd cables? Cheers
Samuel image.jpeg.41a2bb126fa31c0de0687550dc35b61e.thumb.jpeg.f9c847615153a7f27bea353bef02deca.jpeg
By RCD do you Mean RCA, my Alphard has the theatre system with the 7 speakers and rear roof screen, on the back of the centre console bettween the front seats their are 3 RCA sockets, yellow for video, and red and white for audio, if you get a lead with 2 RCA plugs on one end and a 3.5mm jack plug on the other, plug the RCAs into red and white on back of cosole, and 3.5 mm into a music player, or headphone socket of a phone with one and music on it on sd card or internet radio/Spotify etc, then press the TV button on the head unit, whatever is playing on the music player/phone will now play on head unit, was that what you were asking
Chris
Chris
Thanks Chris.
Yes, apologies. RCA connections. Yep, I've also got one with the theatre system although the rear roof screen was removed to fit a poptop roof. I found the rca connections as you said and it works! Brilliant. So simple! I was worried I would have take off the head unit to find suitable connections. I think I'll now get a Bluetooth device that connects to rca and then I won't even have to use the cables. Thanks a lot!
Samuel
Hi, and thanks to all who’ve posted on here. I’m just discovering how the audio ( yes, and video) work on my recently purchased 2006 Alphard. I’ll likely be back with some questions once I’ve had a look around and discovered what is obvious. It was a couple of weeks until I managed to open the head unit for access to CD player (with another port for an SD card like on my old camera). I’ll now have a scout round for RCA connections.
I, too, have drop down screen in rear and remote control. Nothing happens yet ( but remote turns it on). Will fiddle for a while and…..likely be back to pick your brains!
  • 7 months later...
Hi, I also have the ETC card box located in the box between the seats - how did you remove it, do you need to unplug the power cable somewhere (where does it feed back to), or did you just pull the box and leave a cable loose in the seat-box. Thanks
