Hi, we just bought an Alphard 8 seater
It has a Japanese Alpine screen at the rear
How can I connect it to Bluetooth or wire to get a video to play on for the kids?
I can't see the model number
Hello Rachelle,
Hi Rachelle.
It depends on your head unit, the stereo within the dashboard.
The below text assumes that you just have a screen in the rear and no ability to load in DVDs there etc.
Often the rear screen is just a repeater for what's on the front screen when the front is set to say DVD mode. The connection to that rear screen is done via the back of the stereo in the front. But, if your head unit is still Japanese you may find that you can't get UK or European DVDs to play on it anyway.
Can you send a photo and model number of the head unit?
We have a Vellfire ANH20 (2010 model) with a setup like this and are just about to replace the head unit so my research may well pay off for you too.
Tom
  • 4 months later...
I have a 2014 with an Alpine RSA10S-R-SE 10.1″, I don't have any region 2 DVDs to play in the head unit (tested region 4 and yes didn't work). I plugged a portable DVD player into the aux video in (base of the centre console) and while the soundtrack played the video content did not. I mucked around with different setting on the monitor and head uniy but nothing changed.
One win is that I changed the language on the head unit to English and got rid of the default nivi screen and the womans voice telling the etc card wasn't inserted everytime I started the car!
How did you manage to change the language to English. We have an alpine dvd player in the back and can’t get it working either. All we can can hear is the audio of the dvd.
Is it an actual DVD player in the back, or is it just the screen in the back (with DVDs needing to be put into the head unit)?
Is it the original Japanese alpine head unit that goes with the rear screen?
  • 5 months later...
Similar quest here.
If I get a head unit with dvd player and standard video out (yellow rca) will it connect happily to the standard Alpine TMX-R1050VG drop screen?
Edited by twcut
If you have an OEM system you cannot change the language.
If you feed audio in through the RCA jacks you will get analogue sound, whatever the audio source.
You should be able to feed analogue video through the RCA inputs too.
I do not believe you can feed a digital signal to the Gen 1 OEM head units.
On 7/15/2025 at 5:29 PM, twcut said:
Similar quest here.
The Jap van connections are sometimes played about with and end up with something you don't expect once you uncover it all. So, I would check what connection the screen has first (where current head unit is) and then if it's yellow RCA then crack on.
