Hi,  some considerable time ago there was much discussion about rear fog lights and rather than huge expense fitting different lights and reflectors and special switches, I used the one fitted for the MOT,a rocker switch which lit up when switched on. A simple bracket each side of the rear under skirt with rectangular rear fogs, which work well.
Glad I went for the cheap simple fitment as in 3 years ,I've used them once!!!
Sounds good,thought about doing something similar, but went with the easier option. Thought about putting one each side in the rear skirt, but couldn't because the tow bar was just behind the skirt, which left no room to fit the lights in..
Hi Chris, We live up the A30 just past Roadford Lake. Didn't realise there was so much fog around Exeter.
Expand
I commute from Devon to South east London, if i go via Honiton, i quite often hit patches of mist and fog along the a303
