I have this strip fitted aftermarket on the head lights maybe DRL got the car Friday and been fine but tonight they won’t switch off … I have checked for an extra switch but can’t find anything and been fine up until now any ideas. I locked and unlocked the car checked all switches etc took it for a drive and came back but they are still stuck on
DRL should be wired through the ignition switch; but usually run whenever the igntion is on.
Are you suggesting yours do not switch off when the ignition is off ?
Yes
