Many thanks for this. Do you have a diagram for the air con system (hybrid series 1) ? cheers
Yes I do, I will have a look and get it posted up but the A/C system is complicated as it is tied into several systems.
Air con system wiring diagram, 10 series hybrid. The Air conditioner amplifier (2 way)  is located to the left of the radio head unit. The Air Conditioner Amplifier is within the heat/vent/distribution control panel below the head unit.
Air con system wiring ATH10.pdf
So is there a point on the HV inverter you could connect a DC power supply to to charge the HV battery.  So you could run the aircon all night without firing the engine over?
Register a new account
Sign in
