matt chesto Posted 16 hours ago Posted 16 hours ago (edited) does the standard alphard 2007 3ltr front wheel drive have a rear limited slip diferential and is it safe to put the spare tyre on the rear. Edited 13 hours ago by matt chesto
Rojie Posted 13 hours ago Posted 13 hours ago 3 hours ago, matt chesto said: does the standard Alphard 2007 3ltr front wheel drive have a rear limited slip differential and is it safe to put the spare tyre on the rear. No. It does not have a LSD or need one. Although, one was available as an option on some models. What do you mean ? Spare tyre ? Your spare tyre under the boot floor ? Yes, of course, subject to its condition. A spare tyre mounted on the tailgate ? Yes, subject to how it is safely and securely mounted. Although I am not aware of any retail hardware to achieve this.
matt chesto Posted 12 hours ago Author Posted 12 hours ago thanks rojie all it was when i looked in the manual about using the spare tyre because i have a rear puncture it said dont put on rear if you have lsd i wasnt 100% but thought they must mean 4wd thanks
Rojie Posted 12 hours ago Posted 12 hours ago 3 minutes ago, matt chesto said: thanks rojie all it was when i looked in the manual about using the spare tyre because i have a rear puncture it said dont put on rear if you have lsd i wasnt 100% but thought they must mean 4wd thanks I'm sorry. I mis-read your question. No front two-wheel drive vehicle will need a differential in the rear. They do mean a 4wd. I assume this is because the 4wd machines are sensitive to tread wear and grip on all four wheels. Uneven tyre sizes and wear can lead to the wheel speed sensors reporting issues when there are none.
matt chesto Posted 1 hour ago Author Posted 1 hour ago thanks for your help young sir i thought thats what the manual meant but it was not clear just put doubt in my mind
