Hi. My 2007 Alphard has failed its MOT on headlight alignment. Does anyone know how to adjust them?
thanks.
thanks.
Hello Kevin,
I feel sure that this has been covered in the Forum somewhere.
Have you changed your tyre and/or wheel sizes during the last year ?
I had the same alignment issue, and acquired a printout on the method.
It is a simple process, but you will need a level area, a vertical wall, and a length measuring device for the distant from/to the wall.
Most MOT garages should be able to do this for you in a few minutes.
I'll look for my printout, but doubt I will find it; I have several hobbies and many filing 'systems'.
You could search Chris.ac, as he is expert in electrics.
Hi Rojie. Thanks for the reply. I’ve only joined the forum today and brought the van a few months ago.
I’ll search the forum.
cheers.
