Center console cables
Hey all,
I’ve installed swivel bases on both the driver and passengers seat which has resulted in having to remove the center console. When I did that I found some stray connectors that were just plugged into the plastics. Does anyone know if I can use them for anything worthwhile? A USB charger or something?
Edited by kkomitski
Add photo
34 minutes ago, kkomitski said:
Hey all,
Hello Kiril,
One connector is the media connection to the headunit, the other would have been to 110v power adaptors.
Although it would seem your model did not have the ac inverter fitted.
  • 9 months later...
Chris.ac. do ALL models have these cables lurking under the centre console ?
Thnaks.
Stick the black end of multimeter into the chassis and the red end into each pin, maybe you'll get lucky and find a live 12v
