Hi everyone.
I installed android player to my car since 2022.
Before this I never bother about the extra function using canbus box because my car didn't come with 18 unit speaker.
Last year I make a study about the function of canbus and make some modification.
1) I bought the socket for meter 40pin. This socket connect to canbus box and HU. Original for other car.
2) I change the connection point to 13&14 follow the diagram
3) then I bought canbus Toyota from raise.
4) after that setting the HU
You can get information like
- parking trajectory
- door information
- parking radar
- outdoor temperature
- millage odometer
- average consumption
52 minutes ago, ombakjernih said:
Hi everyone.
- door information
- parking radar
- millage odometer
Hello Ombak,
Hi
I looked into getting Canbus information to the head unit but there is no signal in the wiring behind it. It looks in your photo that you are taking it from behind the dashboard which makes sense as all the data is shown on the dash. I think you can also get it from the ODB socket, in fact I bought a cable a long time ago from AliExpress that came with an ODB plug. I never tried it
5 hours ago, Voodoo101 said:
Hi
Yes. Either you tap from meter or obd still the same. this is the wiring to get data Tx & Rx from canH and canL only.
But the obd port I connected with elm327.
Hi Ombak,
Was your Android HU already a 360 camera version or did you need load an app to get the 360 camera function to work? - just bought a 2014 Alphard with the factory 360 camera and the 18 speaker system and am researching Android HU options 🙂
On 3/28/2025 at 11:59 PM, zaphodbb said:
Hi Ombak,
Yes. My HU come with 360 camera. As per new different technology my advise is change with new camera.
You need to buy canbus with decoder amplifier as you mention with 18 speaker.
That is brilliant.
I'd love it if someone could offer that in the UK. I have been looking at head units (I still have the OEM unit) and was concerned that I would lose functionality such as the camera tracking and auto parking. This looks like those functions would be restored.
Which Android unit did you get OP?
It looks like the HU Ombak has is a Mekede Tech model - probably a DUDU 6 or 7. Mekede also own a software development company so are usually ahead of the game for updates etc. This is the brand I've been looking at as they advertise it covers the original HU functions, so ordered the 10.36 inch model from their UK Amazon store (for less that it cost to buy from AliExpress....) they contacted me and offered a better 11" unit C/W with fascia and real buttons/knobs, but it turned out to be nearly twice the price (@£1079), so will re-order the one for £569 (which is the same size as Ombak's), and order the correct fascia from AliExpress (circa £24). Note: (only) if you have the 18 speaker sound system you will also need a combined MOST and CANBUS adapter which range from £90 to £120 from AliExpress.
The DUDU7 models have a USB C port on the back which can feed an external display/touch panel - plan is to feed the roof monitor via this: will see how that goes.
Edited by zaphodbb
Replaced Fibre with MOST
So, in the end I opted for the expensive one, however my advice at the moment is to hold-off buying any alternate HU for the Hybrid version, unless others have had a better experience.
Initial issues are:
1) the at the replacement facia has cut-outs for the non-hybrid gear selector and indicators so needs cutting / modifying to make it fit.
2) first trial fit (without mod to facia) is the car emits a continuous beep when I try to lock it, so looks like there maybe an interaction with the central locking / factory alarm - no time to look at this further at the moment,
3) Factory 360 camera not working, but this may be my fault / not hooked-up correctly
Slight update - point 2 is nothing to do with the HU swap: more a feature of the car when turning it on/off without the brake depressed, so anyone reading this can ignore this point.
I've made a reasonable attempt at re-cutting the facia to fit the Hybrid selector / position legends and tried again - still can't get the factory 360 cameras to work & unfortunately the 360 camera setup is not part of the main wiring diagrams for the Hybrid model. So the factory HU is back in for now.
I've ordered a 16 pin connector from Aliexpress (as the adapter loom doesn't have this) and some other bits for the factory microphone - will try again when the parts arrive.
hi, I have just bought and installed a dudu7 11” HU. Most things work, but not any steering wheel controls. Were yours working ok?
Hi John, yes - well the volume / track I tested worked OK, but then the HU was partially setup already by DUDUAUTO.
My Alphard is a late 2014 Hybrid and has the very long plug for the power and audio plus the steering wheel button sensing wires - yours could be different: it could be two things, the sensing wires are not connected, or you need to program the HU to recognise the buttons.
Did you get any instructions? - mine has a QR code which allegedly linked to the instructions: couldn't located them....
I recently bought a new Head unit from aliexpress, everything connected well as it was plug and play with old android unit. I have managed to get video out to ceiling unit, reverse cam working with trigger, speakers too.
My loom also came with the same Canbus decoder you have but I'm not sure how to get it working, I have gone into the factory settings and selected the canbus to detect alphard but nothing gets detected. Do i need that thick red cable 40 pin? that you have connected up?
Yes. To use canbus you need to have 40pin or connect directly to diagram I share.
@yoyo920 - does your original HU have a long plug like the one in this thread?
@ombakjernih Thank you so much for sharing this thread, it is much useful. I'm considering to follow you on this.
Just two few questions please?
1. Is this still your current setup or you have changed anything further to have more features and is there any side effect from using so far ?
2. Just for me to avoid any mistake, where should I plug the circled part below pls?
So far this setup still same as before. But i try use other brand canbus like Hiworld and not much information I got. Raise canbus can read more data like external temp, odometer and remaining range.
For your 2nd question, the cable you circled, connected to canbus input CanH and CanL.
Many thanks @ombakjernih
My Android Unit is a recent model (Onkyo X-QD1800 https://onkyocaraudio.com/products/x-qd1800)
To my best guess, new Android head unit models have canbus decoder integrated inside (see screenshot below).
I'm thinking i might be able to achieve the same outcome as you but without the need of the black canbus box.
This means it should be possible to connect green + green/black cables directly into CAN-TX and CAN-RX to the back of my Android unit somehow.
And then I can explore using either HiWorld or Raise options from the settings of my Android head unit.
This is in theory though but I derive from a screenshot of my Android unit above. THANK YOU AGAIN for the inspiration through this thread.
You theory is wrong. You still need canbox because only canbox can translate data code from the car to Android HU.
Hi @ombakjernih
Sorry to trouble you again. I'm using the same 20 PIN Raise Canbus decoder box as you. But I struggle to get this working.
Can you confirm if I should connect the circled into behind Pin #11 and #12?
Connect these green wires behind Canbus decoder's pin 11 and pin 12 accordingly
Thank you.
Edited by TonyOh
add more info
On 8/21/2025 at 12:22 PM, TonyOh said:
Hi @ombakjernih
Thank you.
Hi @TonyOh
Yes. Pin 11 & 12 from meter. Then pin 13&16 to HU.
You can refer my photo. If not working, you can swap position pin 11&12
Update here if can work or not.
