I have problem In my toyota vellfire 2011 problem is speed m
My car speed goes 60 if I go to on motorway I try go to speed 70 engine struggle and speed goes down too 60 speed I took it to gearge for repair they said speed sensor gone I told them replacement and then after 3days later the speed problem started again please can anyone give me advice too slove this problem please
Then my gearge advice me too do service twice I did service and still got problem In speed I spent lot of money in this £400 and still got speed problem.
I would get a bluetooth ODB II scaner and the free car scanner app. A lot less the £400. Run the app and driver the car with it connected. See what speed it reads. If it reads different to the speedo then you know its the speedo, if not then you know its the speed sensor. At least then you can also read all the ECU fault codes which will point you in the right direction
Also why would a service help the problem, like and oil and filter change will fix a sensor. It sounds like the garage you are using has seen you as an easy payday.
https://www.ebay.co.uk/itm/235954066700?_skw=veepeak+obd&itmmeta=01JM3238C57G9003MPE66D2Q48&hash=item36eff5550c:g:iKIAAOSwm4Jnq4N4&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fffK0W76y%2BQc55vsiKQACTPm3k8wQl1svxC4C2sJMf7UuNRgWa5X0Q1YqK7DExYHiflToEUnjBUbBt0QKdP09AWOYtFylmKQ%2BMNkzNNc2B8lGvSAYftoDm%2BhsiFajG%2FXMUq39ESK%2FINijBmdDfohaO6S%2BsOr5IpR88HK6SyA0oGuXFXgrKX2LlQKhJuOLaZBovFxa75W1GKUutbRWtkVZ5y8d%2FUejpDzUpLCGlDwR2ZkoFchexM68e9B5gk4GdamU%3D|tkp%3ABk9SR5qGjeKgZQ
Hi voodoo101 thank you so much give me advice on my car toyota vellfire 2011 speed problem I have changed parts speed sensor in 1st February 2025 in birmingham gearge but still issues speed problem 2secd gearge I want he said do full service again twice he cleaned this part throttle too but still speed problem tomorrow I am going too 3rd gearge too see what he says about my car I love my toyota vellfire I brought it in 2013 June price was £10k it's very good car reliability I will post everything on Alphard club what I am going through with my car and with gearges I live in coventry I go to birmingham too fix my car I can't give my car too coventry gearges because they don't have knowledge of japanese cars in coventry
Hi voodoo101 thank you so much you give me advice on my car speed problem I have changed the speed sensor last month end of January 2025 but unfortunately still got speed problem I went to birmingham too show my car 2 garages one garage said speed sensor faulty I said changed it put new speed sensor after 2days problem started again speed getting low now 50mph before speed 60mph it's was OK manging on mScreenshot_20250216_170956_Chrome.thumb.jpg.bc7fba8d928e71335cc20ce96e76e507.jpgScreenshot_20250216_170956_Chrome.thumb.jpg.bc7fba8d928e71335cc20ce96e76e507.jpgotorway 60mph speed and I went to second gearge too show my car he said my totScreenshot_20250216_170956_Chrome.thumb.jpg.bf9b55ca22eed9746e34901267693591.jpg
Veepeak OBDCheck BLE+ Bluetooth OBD II Scanner Car OBD Code Reader Auto Engine Diagnostic Scan Tool for iOS &Hi voodoo101 thank you so much give me advice on my car toyota vellfire 2011 speed problem I have changed parts speed sensor in 1st February 2025 in birmingham gearge but still issues speed problem 2secd gearge I want he said do full service again twice he cleaned this part throttle too but still speed problem tomorrow I am going too 3rd gearge too see what he says about my car I love my toyota vellfire I brought it in 2013 June price was £10k it's very good car reliability I will post everything on Alphard club what I am going through with my car and with gearges I live in coventry I go to birmingham too fix my car I can't give my car too coventry gearges because they don't have knowledge of japanese cars in coventry
Veepeak OBDCheck BLE+ Bluetooth OBD II Scanner Car OBD Code Reader Auto Engine Diagnostic Scan Tool for iOS & plus
Brand
Veepeak
Power source
OBD II Port
Product dimensions
41L x 50W x 22H millimetres
Operating system
IOS, Android
Manufacturer
Veepeak
  • CHECK ENGINE LIGHT DIAGNOSTICS (Generic OBD II Functions) - Read & erase engine diagnostic trouble codes, view freeze frame data, I/M readiness and real-time sensor readings (for example O2 Readings, Engine coolant/ oil temperature, Mass air flow rate, Fuel rail pressure, Fuel Trim, throttle position, etc.) using your phone or tablet via an OBD App like Car Scanner.
  • DO MORE – With extensive third-party OBD Apps available on App Store and Google Play (requires separate downloading or purchase), you can get advanced features like enhanced diagnostics and PIDs on selected vehicles, examine the battery in hybrid & electric vehicles, customize selected vehicles, etc. Please refer to the product images or user instructions for detailed information. Note: incompatible with pre-2008 models or G series when used with BimmerCode.
  • DEVICE COMPATIBILITY - Compatible with iOS via Bluetooth LE (do NOT connect in iOS Bluetooth Settings; please connect directly in the OBD App) & Android devices via Classic Bluetooth (requires Bluetooth pairing; head units may not be compatible). For detailed iOS connection and Android pairing guide, please refer to the product images or user instructions.
  • VEHICLE COMPATIBILITY – compatible with model year 2001+ petrol, and 2004+ diesel vehicles in EU and UK (for generic OBD II diagnostic functions only; for advanced vehicle-specific features like ABS, airbag diagnostics, and manufacturer-specific PIDs like DPF which require special Apps, please refer to user instructions for availability). Hybrid plug-in and electric vehicles require special apps such as Car Scanner (with EV connection profiles), EVNotify, ABRP (iOS) to connect.
  • USEFUL & PRATICAL - updated model with support for more AT commands, optimized firmware and reduced power consumption. Easy to plug in & unplug, and won't obstruct legroom. Comes with mini carrying case and one year replacement warranty. Perfect tool for car owners to check their cars at home or on the go.
  • NOTE: a third-party App is required to achieve all the functions (some may require separate purchase). What features you can get mainly depends on the chosen App and your vehicle. For more detailed vehicle & App compatibility, available functions, App recommendations, FAQ & troubleshooting, please check the product images and find the latest user instructions on Amazon product page "Product guides and documents".
Product specifications it's on Amazon price is
