Hi there I can only get radio 2 ,any tips on how to change things thanks
Just now, russ1966 said:
Hi there I can only get radio 2 ,any tips on how to change things ,the unit is a 56064 ,many thanks
2 hours ago, russ1966 said:
Hello Russell,
You will only get Radio 2. that is normal as the Japanese and British FM bands are different.
You may be lucky and get a couple of other noisy stations.
You can change the headunit, which can be easy, or not.
You can also get frequency changers, or use modern gizmos to achieve your aim.
This is a very common query.
Search the forum for Head Units.
Thanks so much
I only used to listen to Radio 4 on DAB on my M2 Estrima, so finding I can only get Radio 2, I am now a convert and enjoy Radio 2. I occasionally have to retune the Radio 2 as I travel as its not on Digital and loses its signal
