Ath20w hybrid alloy wheel load rating
I'm buying aftermarket alloys for my vellfire 2013 hybrid i know the kerb weight is 2110kg for my zr model but no clue on gross weight or front or rear axle gross limit stuck in choosing alloy wheels as most of them are rated at 680-690kg sorry if it's been asked before
Or does anyone know what the oem 16inch alloys load rating is might be written on the inside of the alloy thanks
Just pop a wheel off and check 👍🏻
Unfortunately I have 18s on mine but the oem 16" only for hybrids tyre rating is 750kg so I assume the minimum rating needed for the hybrid is 750kg a corner lighter wheels should be used with caution
  • 5 months later...
if you look for wheels -- " commercial rated " you will be within space or higher
