Seat Rail / Runner Removal - 20 Series
Hi there,
I've seen quite a lot of information online regarding removing the seat runners from their tracks on the 10 series, but not a lot on the 20 series. Some technical guidelines I found online suggested that they needed to be un-bolted from underneath the vehicle which requires removing the fuel tank. Has anyone found a way to remove the seat runners without having to un-bolt from the underside?
Thanks,
Toby
22 hours ago, T8by said:
Hi there,
Thanks,
Toby
Your profile is set to Gen 1, pre-facelift.
Is that what you have ?
I am not aware whether the fuel tank needs to be removed, or not; the rails are fastened from underneath the chassis floor on Gen 2.
As you say, Gen 1 are removed from above.
As you say, Gen are removed from above.
Thanks for your reply.
I've updated my profile as I made my account before becoming an owner!
It's definitely a gen 2!
