gunay Posted April 6 Posted April 6 (edited) I must have blown a fuse while trying to connect reverse camera trigger signal to 12v reverse (white) light socket. Looked at manual but could not locate where the fuse might be. Checked each fuse one by one in the front two fuse boxes. Under the bonnet. I'm hoping it has a fuse... Edited April 6 by gunay
Rojie Posted April 6 Posted April 6 3 hours ago, gunay said: I must have blown a fuse while trying to connect reverse camera trigger signal to 12v reverse (white) light socket. Looked at manual but could not locate where the fuse might be. Checked each fuse one by one in the front two fuse boxes. Under the bonnet. I'm hoping it has a fuse... Hello G, Welcome to the Forum. 1
gunay Posted April 8 Author Posted April 8 (edited) Figured it out. There is a third fuse box. 🙄 Located Over passenger feet, under the gloves compartment. Not inside. It is (BKUP LP) Backup lights - https://www.startmycar.com/toyota/vellfire/info/fusebox/2018 Edited April 8 by gunay 1
