James Brown Posted June 15 Posted June 15 Hi all, Looking for advice on which part needs attention/ replacing. Engine warning light is on & odometer is not moving from zero. Then whilst driving, revs will drop then surge for split second & warning light goes off & odometer will register for a short period then back to zero with warning light. Any ideas please.
Picasso Posted June 16 Posted June 16 Hello James have you had the engine codes read by diagnostic this is the first thing that needs to be done .
James Brown Posted June 16 Author Posted June 16 Hi lee, Taking to garage, will advise when done. Initially thought that someone would recognise this fault.
Picasso Posted June 16 Posted June 16 It could be a number of things my best guess would be speed sensor on gear box there is 2 fitted
James Brown Posted yesterday at 10:33 AM Author Posted yesterday at 10:33 AM On 6/16/2025 at 4:24 PM, James Brown said: Thanks Lee. Hi again Lee, Looks like you may be right about the speed censors. The auto electrician needs a wiring diagram as he says the 2 wires do not go straight to the speedo head. Is one available on the Forum? Also, part numbers for the 2 speed censors & recommended supplier, Toyota are quoting £168 + vat each. Thanks in advance for any help.
Picasso Posted yesterday at 01:34 PM Posted yesterday at 01:34 PM hello james i have sent you a private message
James Brown Posted 13 hours ago Author Posted 13 hours ago Many thanks for that advice. Does the speed sensor wiring go direct to speedo / odometer head or other ?
