Alphard Body Roll Question
Hi, I am a new member and a new Alphard owner, and really pleased to have finally secured one!  A question, is it possible to reduce the body roll on an Alphard on corners and adverse cambers?  I have seen with VW vans they is a recommendation of fitting anti roll bars, has anyone done this.  I usually drive low, sporty cars, so may just be over sensitive !
Any suggestions gratefully received.
Hello Gina,
I am very close to you at Paignton.
Perhaps you could send me a Private Message with your registration so I can check your MOT history.
I can also advise a local garage, other than Snows, that will work on your van.
You have bought a limousine version of a people carrier so it will wallow a little when compared to your 'sports' cars.
Tyre pressures, and tyre wear, are a good places to start; and adopting a more leisurely driving style could all help too.
Thank you
Edited by Luckyluckyme25
Thought I had sent via private message.
What are your tyre pressures ?
XL (Extra Load) tyre could help too.
Heavier duty rear springs are available, I believe.
Please send me a Private message for the location of the garage.
