hi,
Hoping someone can help,
I've a 2004 3litre petrol alphard,  converted to 4 berth camper.
the entertainment system is turned on via a small circular black switch which is situated between the steering wheel and the touch screen.  The switch has a red led light to show its on.
I was picking up dropped 'stuff' from the drivers side floor, when i noticed  another if these black circular switches on the plastic panel just below the steering wheel.  It was lit up with same red led.
The manual doesn't mention it,
it is a translation and only for the mpv so no camper info.
There's also a blue light at the side of the petrol cap and bonnet opening switches which seems to flicker if i turn off and back on.
any ideas?,
I hope its not for an ejector seat
Kathryn (alphard and camper newby )
20250612_193641.heic
In case you wondered......
The strange switch is to turn rear fog lights on
Of course it is, why did I not know??
It does however cure the problem the garage had of replacement of the fog light bulb,  !
