Hi all, how am I supposed to get into the car if the fob battery dies or the actual car battery dies? I've got keyless entry with touch button on the handle?
I noticed I have a physical key in the fob but can't see anywhere to insert it.
Many thanks
Many thanks
I agree with Chris,
I have an earlier model, but their is a key hole on the drivers side.
If you have smart locking, and I think to do; there will not be any other key holes.
Access is gained by the switches on the mechanical key, the switches on the smart key; and most configurations can be operated from within the vehicle.
Have you changed the battery in your smart fob ?
Do you have a replacement should you need it ?
hold hte key to the door handle ... and then open the door ...
