Hi Everyone
Calling upon all the experience on the forum.
Recently ( not sure when asks my wife has the vellfire day to day) the interior lights stopped working.
The Room light, courtesy lights in the doors, front reading lights, rear cabin lights all stopped working.
I have tried the fuse on the engine bay named DOME (interior lights) and it wasn’t blown. Replaced it anyway but still nothing
Also note it is NOT turned to the off position on the head control. I switch it between on and doors open position, no change.
Any help would be appreciated.
just to note although a likely a separate issue. one of the motorised  side doors sometimes will not close using the inside door handle, but opens fine from the outside door handle and opens/ closes fine from the dead control buttons.
thanks any any help would be appreciated
Could anyone help with the below issue?
is there a relay for the interior lights that could be checked?
The dome fuse is the correct one. There is no relay.
What you will have is several other fuses working in conjunction with the ECU, and the ECU in some cases provides the ground logic.
I've attached the illumination wiring schematic.
IL.pdf
