Morning,
Anyone done a water pump on their 2GR-FE?
I'm looking at some higher milage 20 series cars which may (or may not) need water pumps around 100k miles.
I see guides online for replacement, but in other chassis.
I'm comfortable with spannering and have all sorts of work under my belt (suspension, aircon, timing belts etc)
What am I up against if I need to DIY replace the pump?
10 hours ago, Chris.ac said:
Should be the same as other 2gr-fe models.
Look on YouTube for 'the car care nut', experienced Toyota tech who shows quite of lot of this type of work.
Thanks, I did see that but was after chassis-specific information. Hopefully from someone who had done it on their own 20-series.
I've replaced parts before using generic instructions from other models and clearance / order of operations can be quite different.
For example, a filler neck replacement on a ford focus means dropping the subframe on some models, but not others
Edited by thephatmaster
Thatbe great if you can. I haven't seen a workshop manual for the AH20
1 hour ago, Chris.ac said:
Best i can do share the official maintenance instructions
This is great thanks. If I can't get it running reliably on win10 or 11 then I can spin up an XP VM (or just use the online manual)
Super useful anyway, cheers
