Hi. We’ve got a 2.4 2007 Alphard. I’ve checked the transmission fluid level with the engine running (is this correct?) and it’s at the low level mark on the dip stick. Can someone recommend which grade of fluid to use and where to get it. Also, do I add this fluid carefully through the dip stick tube? Thanks. Kev & Kim.
