I have a problem with my 06 2.4 hybrid, the roof warning light , Vehicle stability light and the ABS light are all coming on after about 100miles running. The OBD is showing a fault as code as p1325 inverter fault. Has anyone come across this or knows what the fault is TIA for any assistance.
Are you sure it is P1325 as inverter faults are P3123-xxx, if so, you need to find the sub code (-xxx) to identify the part in the inverter or wiring to the ECU's.
