Auto light questions
Hi all. My velfire has auto lights. I’ve noticed that during certain conditions the side lights will turn on without the headlights and then when it’s abit darker they turn on all together.
Is this a thing? Can I adjust it? Thanks all
4 minutes ago, Chris.ac said:
Yes, they can be adjusted slightly (5 levels of activation).
I usually do this via 'carscanner' app and a obd2 Bluetooth adaptor.
Thanks Chris. You don’t happen to know how to change the interior room strip lighting? Just changed all my map lights for leds. Wanted to change the room lights too. I have the two long strips .
They have 2 LEDs per strip. One at each end.
The length is a plastic diffuser.
On AliExpress you can buy some upgrade led units that are also colour changing.
They just replace the modules sheet in place and you get an additional switch that fits into a blank position that allows you to cycle colours.
1 hour ago, Chris.ac said:
If you buy an obd2 adaptor, you will get access to all the dealer ECU settings.
This is the auto headlight settings menu.
Awesome thanks for your help mate.regarding the roof lighting am I searching for anything specific. Sorry for being dumb. Just want to ensure I’m getting the correct things.
An integrated one that was specifically designed to reuse the plastic diffuser is more expensive than some of the other options.
Here is the one i found a number of years ago.
Other members have installed better lighting.
I just found this on AliExpress:
£134.39 | for ALPHARD VELLFIRE 20 series Ceiling Atmosphere Lamp Indoor LED with Button Switch 2008-2014 Year
https://a.aliexpress.com/_EHcv7d2
Thanks mate. I found a video on YouTube from around ten years ago. A guy removed what appears to be led it clip in part to each end of the strip to replace the factory one. However I can’t seem to find any of the sort.
