New head unit, update and advice on interior light requested
Have not posted anything since my first attempt to understand how to stop the door mirrors automatically folding away when locking the car and now I could do with a bit more advice so here's a general update on my 2010 V6 Alphard.
Soon after getting the car in September 2025 I drove it to Germany and back without any issue and it ran well - It proved itself to be a comfortable and practical vehicle over long distances while carrying wife plus two dogs and all luggage for a long stay.
Over Christmas / New Year 2025/26 – I removed the old original JDM head unit and replaced with Pioneer AVL – Z5200DAB head unit which I chose after soliciting advice from as many people as I could find to ask. Much more work and much more challenging than I thought it would be, but I am very happy with the end results. Now it can receive UK radio and DAB.
The car had several aftermarket accessories fitted in Japan, including a TV tuner (Japan only) and a separate DVD player (fitted in the glove compartment) which both fed the Alpine rear screen. With all of the wiring adaptors it had fitted it took me the best part of a week to figure out what was original and what was not so I could carefully remove all of the Japanese aftermarket items. Purchased all of the necessary adaptors and fittings from Dynamic Sounds who were brilliant with excellent and patient advice. With their help retained steering wheel control functions. Rear drop down TV screen now works from the DVD player in the new Pioneer head unit.  The original reverse camera was 6 volt and powered by a special feed from the old head unit so this had to be changed to 12volt. I purchased and fitted a Pioneer reverse camera compatible with the new head unit and I think that it is actually a better camera than the original.
At the beginning of March this year I changed front suspension strut rubber gaiters. The parts were supplied FOC by the importer after I complained that the perished condition of these gaiters should have been an advisory at the MOT which was done before I collected the car. The condition of the front struts and upper strut bearing plastic discs in particular makes me believe the low mileage is genuine, it was  61,329 kilometres (38,108 miles) when I first picked it up.
At the same time, I tried to deal with a small dent in the front wing behind the front left hand side wheel. The auction inspection in Japan stated the body work was perfect, so I assume that this happened in transit from Japan. I was able to access the panel from behind and managed to push most of it out. Now it is hardly noticeable.
A few days ago at a mileage 65,745 kilometres (40,852 miles) I changed the oil. The importer did change the oil before delivery but I suspect it would not have been synthetic or particularly high quality and also I want to ensure it does not have 0W – 20 oil which is one of the grades specified for the Japanese market and elsewhere.  The oil that came out was very clean and evidently quite new but also very thin so I suspect it was 0W – 20. Filled with Mobil 1 Full Synthetic ESP 5W – 30, I think that this grade of oil is much more suited to operation in warm weather and will consequently help preserve the engine. May even switch to Mobil 1 0W – 40 in the future as this is the oil I use in my old Lexus GS300. Had to buy the service tool for this type of oil filter housing as none of my existing tools fitted, works very well.
Now to the part where I need advice from the forum - If you see the two attached pictures you will see the back of the interior light over the rear right hand side passenger door. In these views my grubby finger is on top of the connector block which contains the switch mechanism and the bulb holder – This connector block clicks into the main light/air vent assembly which locates in the headlining.
I think that the connector block/switch and bulb holder is defective and the reason the light does not work but I cannot manage to remove it from the wiring harness. I have poked, pulled and prodded for hours on end and short of destroying it I just cannot see how it is supposed to come off. I wonder if it is integral with the wiring harness that routes behind the headlining.
If this connector block is available I would buy one anyway just to see how it is supposed to fit. I have tried to find schematics on line but can’t find anything of value and it is driving me up the wall. If anyone has managed to remove one of these please share your wisdom, I would greatly appreciate any help.
By the way I did finally get hold of a former Japanese colleague to ask for his help with the folding door mirror saga and if he does come up with anything I will post it on the forum.
All the best
Malcolm
Update - I managed to get some Toyota schematics, those connector blocks are integral with the wiring harness and do not come off - So if I am right about the fault being in there, then it will mean the headlining will need to be removed. Let's hope I am wrong and the fault is elsewhere.
