Craigb Posted August 2, 2021 Posted August 2, 2021 Just picked up my 2005 alphard. Looks like it has a front camera but no idea how I get it to work. Rear works fine when I go in reverse
AlphardZA Posted August 4, 2021 Posted August 4, 2021 hi, @Craigb you switch it on on the steering wheel, the camera goes on automatically when you put it in Drive, when you start driving it will go off, but when you slow down just before you come to a standstill it will come on again. 1
Jacksalf Posted April 9, 2022 Posted April 9, 2022 Hi Craigb, did this work for you? im having the same problem with the front camera.
Craigb Posted April 9, 2022 Author Posted April 9, 2022 Yes, there should be a button on steering wheel. Then front camera should come on, for manoeuvring. It doesn't stay on for normal driving 1 1
Rojie Posted April 9, 2022 Posted April 9, 2022 The 'front' camera, if you have one looks sideways and downwards. Not straight ahead. Great for 'Peep and Creep', and 'seeing how close you are at the front when parking. It isn't a dashcam! 1
AusToyota Posted October 3, 2022 Posted October 3, 2022 Hi, I wonder anyone can help me out on the front camera wiring. I have the 10 series with front camera, but at some point the original head unit was changed. I took the front camera off and tested indoor and it work fine but the problem is I have no idea which colour wire or wires wired into the vehicle's head unit for the front camera to plug into. Anyone kindly advise ? May be a wiring diagram or a photo so that I can locate it and connect back to my head unit. Thank you
Mikli Posted October 4, 2022 Posted October 4, 2022 Would it be easier to just replace with an aftermarket front camera to connect with your aftermarket headunit?
Rojie Posted October 4, 2022 Posted October 4, 2022 9 hours ago, AusToyota said: Hi, I wonder anyone can help me out on the front camera wiring. I have the 10 series with front camera, but at some point the original head unit was changed. I took the front camera off and tested indoor and it work fine but the problem is I have no idea which colour wire or wires wired into the vehicle's head unit for the front camera to plug into. Anyone kindly advise ? May be a wiring diagram or a photo so that I can locate it and connect back to my head unit. Thank you If you search through Chris.ac, and there are a lot of threads from Chris, you should be able to identify which sockets do what on the rear of your head unit (depending on which one you have). 1
Register a new accountSign in
