Driver's Side Window Openers Not Working
I thought I'd make a specific thread for this issue, as I couldn't find one anywhere. I provide the solution too!
This thread is referring specifically to the cluster of 4 window open/close buttons located in the driver's door.
Having owned the Alphard for a couple of weeks I noticed that the button for the driver's door window works, but the buttons for the other three windows don't work.
However, all three passenger windows work fine when you use the buttons on each specific door.
In another thread (rear window de-mister) someone posted about the reset procedure for the windows (window down & hold button for 10 sec, then window up & hold button for 10 sec, then repeat the process just to be sure). I tried it and HEY PRESTO all 4 buttons on the driver's console work again!
SOLUTION
So, if you have this issue, try the reset procedure for each window, one by one, using the buttons in each individual door, as described above, and you may have success. I certainly did.
Apologies if this topic already exists elsewhere - I haven't been able to find it.
