Eric L Posted September 29, 2021 Posted September 29, 2021 Hi all, Â My name is Eric, I live in the UK and recently acquired an Alphard which I'm planning to slowly convert as a camper. Â First thing I'm trying to do is to remove the middle seats and the foot rest. I noticed that this model is slightly different from other Alphards which have rotating seats. Mine the seats slides back and forth but doesn't rotate. Â I couldn't find any info in YouTube, so does anyone have any hints? Â Â Thanks, Â Eric
Rojie Posted September 29, 2021 Posted September 29, 2021 Hi Eric, Â Is your Alphie an MZ version. Â I have an MZ version with leather Captains seats and foot rests. Â Unfortunately, the middle seats do not rotate, even with the footrests are removed. Â You can purchase swivel bases for the front seats, but the supplier (IOW) informed me that they do not fit the middle Captains seats. Â Silly suggestion time... is to change the middle seats. The swivel versions can can be obtained on ebay (or a breakers yard). Indeed there were (maybe still are) some dark ones for sale in this forum. Â I am working on a way of overcoming this issue but am keeping stum until (IF) I get it to work.
Rojie Posted September 30, 2021 Posted September 30, 2021 Just to clarify the above. Â IF you have the MZ G edition, or your machine is a seven seater, your seat rails will have a different spacing that most other Alphies. Â So if you do go down the 'change your seats' option you will need two single seats. The 'one and a half' seat (small bench seat) will not fit the MZ seat rails. Â It may be possible to exchange the bench seat chassis for the Captain seat chassis, or swap the swivel mechanisms over. I have not tried either, although I would not expect it to be achievable. Â I have two single seats, but have not fitted them yet, so even that might not be possible !
Eric L Posted October 6, 2021 Author Posted October 6, 2021 Thanks for your reply.  For now I'm not concerned about changing the seats. I really want to just remove then, as I'll fit some sort of bed. Unfortunately I can't find resources to disassemble seats/foot rests and I'm not very good at figuring out myself 😞
Rojie Posted October 6, 2021 Posted October 6, 2021 I have never removed seats (yet) so cannot help you there; but, I believe, it is quite simple. Â Most seats will fold flat to make a flat area for sleeping, maybe not flat enough but.....
