Dave_R Posted March 11, 2024 Posted March 11, 2024 I read all the advice in these forums and searched through the Ali Express listings for Alphard/Vellfire Android wiring harnesses. After a few false starts I found this one which appeared to have all the right connectors. "16PIN Android Radio Power Cord Wiring Harness For Toyota Alphard Vellfire AH20 2008-2015 Car stereo Fiber Box Adapter Canbus" https://www.aliexpress.com/item/1005006000618979.html 1
Dave_R Posted March 11, 2024 Posted March 11, 2024 (edited) Problem 1. Audio Plugging everything together went well. The 16-pin Android head unit, the MOST box, and the car plugs all go together and there's generally only one way as the connectors are all unique to each other. The head unit turned on successfully and its now time to test all the functions. Bluetooth and CarPlay worked. I was able to pair my phone and control the head unit. Because it's Android based you have to manually run the "TLink" app to enable Carplay. Now the first issue became apparent - no audio. I was unable to get any audio from the speakers at all. At last, in desperation I connected the head unit's AUX audio out to the MOST box AUX audio in and suddenly we are wired for sound. To do this I had to use the RCA connector harness that came with the head unit. This has an android 20-pin connector on one end and a whole bunch of RCA connectors and a GPS on the other end. The MOST box came with an RCA AUX input cable already attached. Its partly visible at the bottom of the photo below but it's just two RCA plugs for Left and Right audio. With these AUX connectors connected audio works and it sounds pretty good. Note: there's a lot of misinformation in the labelling of these audio harnesses. They talk about fibre optics but there are no optical fibres in 2nd generation Alphards/Vellfires. I believe its a digital audio connection between the head unit and the under-seat amplifier and thats what the most box provides - it converts analog audio from the new head unit to digital format for the amp. This is all done on copper wiring so not really fibre optics at all. Some people avoid all this by removing or bypassing the amplifier and installing a new analog wiring loom from the android head unit to the amplifier speaker outputs, but thats seems like a lot of work. There are YouTube videos showing how to do it if you are interested. Installing the MOST box avoids all that extra labour and uses the existing wiring. As a bonus the MOST box includes CANBUS so I found that steering wheel controls for example worked as soon as I'd told the head unit that the car was an Alphard. Edited March 11, 2024 by Dave_R 1 1
Dave_R Posted March 11, 2024 Posted March 11, 2024 Problem 2. Reversing Camera The reversing camera did not work out of the box. The MOST box/wiring harness I bought included a small controller labelled CANBUS but which is actually a GVIF to RCA video adapter. I was confused for a while because the car does not have a blue reversing cam video connector. It does have a green GVIF connector but thats for in-car video entertainment (I think - please correct me if anyone knows). Again I eventually tried using a small android to RCA video cable (pictured) that came with the head unit and connected the RCA end to one of the two yellow RCA sockets on the MOST harness. This proved to be the correct thing to do but I did not know because there head unit was supplied with 360° camera software, but the car does not have 30 cams, just a regular reversing camera . I will not say how many hours I spent trying to configure the 360° cam software to use the reversing cam, but after much trail end even more error I git into the Facoty Settings and disabled the 360° camera software and, like magic - but with more colourful language - the reversing camera started working as expected. The car's steering-responsive curved reversing guides don't show up any more but I can live with that. Mostly. The GVIF-RCA converter was not needed in the end. 1
Dave_R Posted March 11, 2024 Posted March 11, 2024 (edited) Problem 3. Microphone inputs no longer working. Problem 4. Radio doesn't work well - sounds like antenna is perhaps not connected properly. Problem 5. USB connector cable fell down the back of the dash and I can't reach it These are all problems to be worked on next weekend! Progress reports to follow. For now everything important works, CarPlay audio, navigation, steering wheel controls are all ok. My car does not have roof video or 18-speaker sound so I can't speak to those functions. I left the original physical aircon controls in place so no issues there. Edited March 11, 2024 by Dave_R
smurf Posted March 12, 2024 Posted March 12, 2024 I'm sure I read somewhere about needing some extra jiggery pokery to get an aftermarket headunit to work with the OEM microphone. From what I read it was worth the effort as the OEM microphone system is high quality. I might be talking rubbish though as I've read a lot recently. As regards the radio signal, is there an aerial amplifier hidden somewhere that needs a signal from the headunit to turn on? I have seen this situation on other cars with aerial amplifiers, and there is normally a blue wire in the harness for turning on amps.
burjaw Posted June 3, 2024 Posted June 3, 2024 On 3/11/2024 at 10:58 AM, Dave_R said: Problem 1. Audio Plugging everything together went well. The 16-pin Android head unit, the MOST box, and the car plugs all go together and there's generally only one way as the connectors are all unique to each other. The head unit turned on successfully and its now time to test all the functions. Bluetooth and CarPlay worked. I was able to pair my phone and control the head unit. Because it's Android based you have to manually run the "TLink" app to enable Carplay. Now the first issue became apparent - no audio. I was unable to get any audio from the speakers at all. At last, in desperation I connected the head unit's AUX audio out to the MOST box AUX audio in and suddenly we are wired for sound. To do this I had to use the RCA connector harness that came with the head unit. This has an android 20-pin connector on one end and a whole bunch of RCA connectors and a GPS on the other end. The MOST box came with an RCA AUX input cable already attached. Its partly visible at the bottom of the photo below but it's just two RCA plugs for Left and Right audio. With these AUX connectors connected audio works and it sounds pretty good. Note: there's a lot of misinformation in the labelling of these audio harnesses. They talk about fibre optics but there are no optical fibres in 2nd generation Alphards/Vellfires. I believe its a digital audio connection between the head unit and the under-seat amplifier and thats what the most box provides - it converts analog audio from the new head unit to digital format for the amp. This is all done on copper wiring so not really fibre optics at all. Some people avoid all this by removing or bypassing the amplifier and installing a new analog wiring loom from the android head unit to the amplifier speaker outputs, but thats seems like a lot of work. There are YouTube videos showing how to do it if you are interested. Installing the MOST box avoids all that extra labour and uses the existing wiring. As a bonus the MOST box includes CANBUS so I found that steering wheel controls for example worked as soon as I'd told the head unit that the car was an Alphard. many thanks with this solution i already can make it running for original sound audio running with canbus module.mp4
burjaw Posted June 3, 2024 Posted June 3, 2024 On 3/11/2024 at 11:12 AM, Dave_R said: Problem 2. Reversing Camera The reversing camera did not work out of the box. The MOST box/wiring harness I bought included a small controller labelled CANBUS but which is actually a GVIF to RCA video adapter. I was confused for a while because the car does not have a blue reversing cam video connector. It does have a green GVIF connector but thats for in-car video entertainment (I think - please correct me if anyone knows). Again I eventually tried using a small android to RCA video cable (pictured) that came with the head unit and connected the RCA end to one of the two yellow RCA sockets on the MOST harness. This proved to be the correct thing to do but I did not know because there head unit was supplied with 360° camera software, but the car does not have 30 cams, just a regular reversing camera . I will not say how many hours I spent trying to configure the 360° cam software to use the reversing cam, but after much trail end even more error I git into the Facoty Settings and disabled the 360° camera software and, like magic - but with more colourful language - the reversing camera started working as expected. The car's steering-responsive curved reversing guides don't show up any more but I can live with that. Mostly. The GVIF-RCA converter was not needed in the end. this 1 also running with original camera and trajectory line from the steering back camera original.mp4
burjaw Posted June 3, 2024 Posted June 3, 2024 i wonder now how to attach the android head unit video output to the original roof monitor ? maybe somebody already have experience to share ?
vk123 Posted June 15, 2024 Posted June 15, 2024 On 6/3/2024 at 8:45 PM, burjaw said: this 1 also running with original camera and trajectory line from the steering back camera original.mp4 Hello. Did your original factory headunit have the blue connector for reverse camera?
Syafik Posted September 13, 2024 Posted September 13, 2024 Please help me i dont no what speaker wire head units bt013a model
derekbenjaminmusic Posted January 20 Posted January 20 On 9/11/2022 at 5:27 AM, Chris.ac said: I PMed you a link to my google share, with the wiring diagram and manuals Can you please send me the wiring diagrams as well? I'm stuck on a couple last things.
Chris.ac Posted January 20 Posted January 20 4 hours ago, derekbenjaminmusic said: Can you please send me the wiring diagrams as well? I'm stuck on a couple last things. Send me your email via pm
derekbenjaminmusic Posted January 21 Posted January 21 On 12/22/2023 at 3:12 PM, threepot said: Well look at that.... All it actually needs is the Pin 1+2 on F14 for the NTSC video in signal. Then if you press the G button on the remote the screen pops out anyway. 🥳 Hey! So I setup the pinout and have my android recognized there's a second screen, but for the life of me I can't get the rear screen to go into tv or aux mode. It opens to a display that shows "am fm DVD hdd" but none of the buttons on the remote will take me to a mode where I can see the aux input. Not sure what that's all about. Any ideas?
zaphodbb Posted April 26 Posted April 26 @Dave_R - do you have a better picture of the GVIF to RCA video adapter or can tell me what the model number is? I think I will need one of these as my car has the 360 cameras / parking assist.
Dave_R Posted April 29 Posted April 29 (edited) Hi @zaphodbb, this is what I have - Its labelled "Can Bus Decoder" but it doesn't have the connections for anything like that, just a Vout RCA and the blue GVIF plus power and an ACC lead. It assume its a GVIF to RCA converter for a rear view camera. It came as part of this https://www.aliexpress.com/item/1005006000618979.html Edited April 29 by Dave_R
zaphodbb Posted April 29 Posted April 29 Hi Dave_R thank you for the quick reply - my car has the 360 cameras / Park Assist which has a blue plug, and I'm pretty certain this is what's needed to feed the video to the Android HU I have going by the post by Threepot in Dave Murrell's Roof Monitor thread and another post by Chris.ac re the factory HU socket identification. Now I have the details, I'll search Aliexpress for the best price 🙂
Kash Posted August 26 Posted August 26 On 3/11/2024 at 3:58 AM, Dave_R said: Problem 1. Audio Plugging everything together went well. The 16-pin Android head unit, the MOST box, and the car plugs all go together and there's generally only one way as the connectors are all unique to each other. The head unit turned on successfully and its now time to test all the functions. Bluetooth and CarPlay worked. I was able to pair my phone and control the head unit. Because it's Android based you have to manually run the "TLink" app to enable Carplay. Now the first issue became apparent - no audio. I was unable to get any audio from the speakers at all. At last, in desperation I connected the head unit's AUX audio out to the MOST box AUX audio in and suddenly we are wired for sound. To do this I had to use the RCA connector harness that came with the head unit. This has an android 20-pin connector on one end and a whole bunch of RCA connectors and a GPS on the other end. The MOST box came with an RCA AUX input cable already attached. Its partly visible at the bottom of the photo below but it's just two RCA plugs for Left and Right audio. With these AUX connectors connected audio works and it sounds pretty good. Note: there's a lot of misinformation in the labelling of these audio harnesses. They talk about fibre optics but there are no optical fibres in 2nd generation Alphards/Vellfires. I believe its a digital audio connection between the head unit and the under-seat amplifier and thats what the most box provides - it converts analog audio from the new head unit to digital format for the amp. This is all done on copper wiring so not really fibre optics at all. Some people avoid all this by removing or bypassing the amplifier and installing a new analog wiring loom from the android head unit to the amplifier speaker outputs, but thats seems like a lot of work. There are YouTube videos showing how to do it if you are interested. Installing the MOST box avoids all that extra labour and uses the existing wiring. As a bonus the MOST box includes CANBUS so I found that steering wheel controls for example worked as soon as I'd told the head unit that the car was an Alphard. @Dave_R You are a savior . I just installed an android head unit with the same canbus box and had only 2 issues. Audio not working and the back camera (that came with the head unit) not kicking in when putting the car in reverse. Thanks to you, audio issue sorted quite quickly as I was getting worried about potential wiring hell I may have to go into. Mine is also the simple one (not the 18 speaker system) and do not have the back screen either. I bought the android head unit with the 360 camera system, cameras are all working great. Just need to get them fitted properly as my Vellfire did not come with any cameras except the reverse one. This means opening up all door panels, removing wing mirrors, drilling holes in them for the aftermarket side cameras as well as fitting one in the front grill too This camera fitting seems more than I can handle I think so might book with someone although no one these days likes to do a partial job as it makes less money for them Lets see. But apart from that really happy with the head unit, really simple plug n play with the canbus box. Can't go too wrong with the wiring with that (except for the silly audio mistake obviously, I had put Aux in to Aux in not thinking it should be going out from the head unit). All steering controls worked out of the box as soon as you setup canbus and tell the car model (I had to select Alphard). Everything else like GPS, 4G Sim and android auto works great. Might disable android auto alltogether to be honest as its a full fledge android system on its own so I can just install the apps I want and just use the BT for calls with phone unless someone convinces me otherwise . All in all, very happy with the purchase. I have an 8GB/256GB system with the ADAS front recorder and the 360 camera system. Cost me £167 for the head unit (with AliExpress amazing sales). The only problem or slight issue I had was that the seller made me purchase a separate canbus box (£70 again in sales) and that came earlier than the head unit and when the head unit arrived, it also had the canbus box in it 😶 So now I have an extra canbus box which I will keep if the one with the unit breaks down ever.
madforce66 Posted 13 hours ago Posted 13 hours ago On 9/10/2022 at 4:54 PM, Chris.ac said: Yes, I now have the wiring diagrams for 2008>2010 for the JDM version of the alphard, all the right sockets and wiring for the headunit Hey chris.ac, any chance of the wiring diagram you have so I can make sense of the connections for the head unit in the first post, cheers Martin
madforce66 Posted 10 hours ago Posted 10 hours ago On 9/10/2022 at 4:54 PM, Chris.ac said: Yes, I now have the wiring diagrams for 2008>2010 for the JDM version of the alphard, all the right sockets and wiring for the headunit
