Guys is there a video or description anywhere showing how to remove the 2nd and 3rd row light units. Need to access wiring and don't want to break anything.
Many thanks Chris. Need to remove the whole unit, vent and light?
the diagrams do not refer to removing the surround expect when removing the entire roof lining - maybe if i look under the heating system diagrams! give me a moment.
edit: nope, cannot see a drawing showing how to remove the vents themselves, bizarre.
Edited by Chris.ac
Thanks anyway Chris.
This might be a bit late but, to remove the whole unit use a flat thin trim removal tool, insert it between the unit and the lining at the end towards the rear of vehicle, push it in and it will push a metal retaining clip over, then lever that end up until it is clear of the lining and move the whole unit backwards until the 2 prongs at the front are clear, if the metal clip gets broken do not worry as the unit is quite a tight fit and will stay in place with out it
Many thanks, will give this a go.
