Darren Eyles Posted May 18, 2022 Posted May 18, 2022 Has anyone managed to get a replacement key for their van, if so how did u do it?
Rojie Posted May 18, 2022 Posted May 18, 2022 2 hours ago, Darren Eyles said: Has anyone managed to get a replacement key for their van, if so how did u do it? I bought some off ebay. Be sure to get the correct frequency. About £15 Toyota Alphard 05-09 Remote Car Key Fob with 4D67 Chip 314.3MHz 4Buttons. Getting it programmed can be quite a challenge. Toyota dealers won't do it. You will need a competent auto locksmith and expect to pay £80 each ! Not cheap, but mine work perfectly. These are not the Smart Key fobs. Good Luck
Teekay Posted May 19, 2022 Posted May 19, 2022 On 5/18/2022 at 7:47 PM, Darren Eyles said: Has anyone managed to get a replacement key for their van, if so how did u do it? not applicable to your situation may be but if anyone importing car, I believe you can request an extra key made there itself for about 150 usd
Darren Eyles Posted May 24, 2022 Author Posted May 24, 2022 Right an update, after ringing around and being quoted from £65 to £150 pounds, so I bought a four door blank for eBay for £18.99, followed the instructions on how to program it myself, it works a treat 1 1 1
Teekay Posted May 24, 2022 Posted May 24, 2022 34 minutes ago, Darren Eyles said: Right an update, after ringing around and being quoted from £65 to £150 pounds, so I bought a four door blank for eBay for £18.99, followed the instructions on how to program it myself, it works a treat That's some achievement 👍👌🥳 Do you mind sharing the instructions or share pointers / resources used? 1
Teekay Posted May 24, 2022 Posted May 24, 2022 I was going to ask if anyone done remote start key? But I'll start new thread for that as it is a topic in itself. By the way also please share the eBay link
Teekay Posted May 24, 2022 Posted May 24, 2022 Wonder if anyone done GEN 2 key programme (keyless entry type)
Darren Eyles Posted May 24, 2022 Author Posted May 24, 2022 55 minutes ago, Teekay said: I was going to ask if anyone done remote start key? But I'll start new thread for that as it is a topic in itself. By the way also please share the eBay link I have seen these on YouTube aswell
Teekay Posted May 24, 2022 Posted May 24, 2022 13 minutes ago, Darren Eyles said: I have seen these on YouTube aswell I'll try to dig but please keep sharing your finds By the way keyshell for Gen 2 Key https://www.ebay.co.uk/itm/195048277984
Chris.ac Posted May 25, 2022 Posted May 25, 2022 gen 2 key programming takes less than 6mins via techstream, you need at least one working 'key' 1
Teekay Posted May 25, 2022 Posted May 25, 2022 31 minutes ago, Chris.ac said: gen 2 key programming takes less than 6mins via techstream, you need at least one working 'key' Thanks Chris, highly knowledgeable as always 👍 This seems to be talking about it ^..I'll look more into it and what all is needed, where to get empty key etc.
Darren Eyles Posted May 25, 2022 Author Posted May 25, 2022 Update, I had a key cut today, it turns the engine over but won’t start it, anyone got any ideas why this could be?
Rojie Posted May 25, 2022 Posted May 25, 2022 (edited) 1 hour ago, Darren Eyles said: Update, I had a key cut today, it turns the engine over but won’t start it, anyone got any ideas why this could be? Yes. You need an autolocksmith AND a master key. Mine worked fine after the locksmith worked his magic ! He also made all my other keys masters ! Or so he said. My guess is your key was cut, but it seems the immobilser is still active. Do the four buttons work ? Lock, unlock, electric doors ? When you get someone to program it, check that all functions work before paying for the work ! Edited May 25, 2022 by Rojie Addition 1
Darren Eyles Posted May 25, 2022 Author Posted May 25, 2022 4 minutes ago, Rojie said: Yes. You need an autolocksmith AND a master key. Mine worked fine after the locksmith worked his magic ! He also made all my other keys masters ! Or so he said.
Darren Eyles Posted May 26, 2022 Author Posted May 26, 2022 Thanks Rojie, all the buttons work and the engine turns over just won’t start, I’m almost there I think😁
Chris.ac Posted May 26, 2022 Posted May 26, 2022 (edited) immobiliser - you transponder in the key has not been linked to the ecu to be clear, there are two ecu involved, one related to the button operations, another for the security Edited May 26, 2022 by Chris.ac 1
Liz Coles Posted June 5, 2022 Posted June 5, 2022 Where did you get your key cut? Was it a specialist or your corner Timpsons?
Rojie Posted June 5, 2022 Posted June 5, 2022 37 minutes ago, Liz Coles said: Where did you get your key cut? Was it a specialist or your corner Timpsons? Hello Liz, Getting the key cut is the very easy part. It is the programming that is the tricky bit ! Timsons cut mine, but couldn't / wouldn't program it. I found a local auto locksmith and all done correctly. I can PM you the company, but it is geographically close to me; WSM may be too far for them. 2
Catweazle Posted October 4, 2022 Posted October 4, 2022 Hi, Continuing with this as I've reached a strange impasse with my key.... I have 2 genuine Gen 1 Toyota keys with 4 buttons, 1 Grey master key with no electrics, and a fob with 3 buttons for lock/unlock/boot. Everything works as it should. 1 of the keys with 4 buttons has worn out, and the buttons are falling out. I've bought 1 key off ebay which is a blade blank attached to the back plastic shell-an empty shell with 4 new buttons on. I've removed the innards of the working key and put it all inside the empty shell, and had the blank blade cut to the working key. Tried today and the engine turns over, but won't start. All the buttons on the new shell work. Any ideas? Poorly cut key?
Arthur Posted October 4, 2022 Posted October 4, 2022 On 6/5/2022 at 10:08 PM, Rojie said: Hello Liz, Getting the key cut is the very easy part. It is the programming that is the tricky bit ! Timsons cut mine, but couldn't / wouldn't program it. I found a local auto locksmith and all done correctly. I can PM you the company, but it is geographically close to me; WSM may be too far for them. Timpson corporate policy is to refuse to cut customer supplied blanks. Think Rojie must have been lucky with the branch he used or their policy has changed since he had his keys cut.
Catweazle Posted October 4, 2022 Posted October 4, 2022 (edited) 1 hour ago, Catweazle said: Edited October 4, 2022 by Catweazle
