Need Help
 I’m trying to locate a part for my Toyota Alphard Hybrid 57 Reg. The Air Con Compressor has gone and seemingly parts are hard to come by.
Anyone you can recommend?
34 minutes ago, Alam said:
Need Help
Do you need parts, or the whole compressor ?
If parts, do you know which parts you need ?
As most, if not all, Alphards and Lexus have AC, my guess is Toyota will be able to help; but you will need part numbers first !
Maybe the compressors on Alphards are unique, but I cannot conceive that to be true.
Compressor from other Toyotas may fit, but checking could be tricky.
Unfortunately no. This is pump. I need the compressor that is driven by the belt
The part is so obscure it’s difficult to get to without a mechanic physically removing it. DB6C8F3B-689D-4CB4-A3E3-61BFC9309D7D.thumb.jpeg.7d8a7a9cd0c1a274b47500991f1becc8.jpeg
this is what I found online
