Issue in CARVX.JP report - recall / airbag?
I was looking at one CarVX.jp report and under recall it says as below. I'm trying to make sense of it and understand its seriousness - any help will be appreciated.
"In the inflator (inflation device) of the passenger airbag, the prevention of moisture absorption of the gas generating agent is inappropriate, so that the gas generating agent may deteriorate due to repeated changes in temperature and humidity. For this reason, the inflator container may be damaged when the airbag is deployed."
Is this fairly common thing? Can anything be done in UK to address this? Toyota uk won't do anything by default?
IF a members vehicle is subject to a recall that has not been carried out Toyota UK will send a notification / request to Toyota Japan.
If Toyota Japan verify the claim Toyota Japan will fund Toyota UK to do the work.
I have read the approval process can take quite a while !
Toyota UK can also check through official Toyota channels whether there are any outstanding recalls.
Thanks Roj this is  reassuring
  • 3 years later...
Hi, new to the forum, and collecting my Alphard 2012 tomorrow. My CarVX report also flags the airbag recall (March 2017). I wonder if we ever reached a verdict on whether it needs further investigation? Thanks
Put the chassis number into this website and it will tell you if it has been done. It probably has, but it shows up in the Car X report regardless.
https://www.toyota.co.jp/recall-search/dc/en/search
Edited by smurf
