I posted this in general chat, but then thought it may be better in the forum.
I have an Android head unit but it seems that all the features do not work properly, mainly to do with reading the canbus, so I removed the unit to check the wiring and I have one connection spare coming from the head unit. This is not really surprising as I have never found a car yet that has the same connections, so it may just be a common adaptor, but I have three wires in the car that I have no idea what they are. I was hoping somebody could identify them. One lead does sort of fit in the spare connector, but is not the same size.
Sorry about the fussy pictures, my phone is on its way out.
 Have you seen the canbus decoders like in this video:
I don’t know much about them but maybe someone else does.
I guess they convert the communications going back an forth into a format the radio can understand.
Yeah I saw that, but the ANH20 is different and that seems to be for the amplifier. But thanks
Voodoo101, on my GGH20W, so far I believe this is the wiring for the main power socket (lots of measurements and scratching about on japanese forums)
  PIN Colour Name
  1 Yellow +B1
  2 Grey ACC1
  3 Red (B?) IG
  4 B MACC Microphone
  5 W MIN+ Microphone
  6 R MIN- Microphone
  7 Shield (WB) SGND Microphone
  8 - TEST
  9 -
  10 Brown GND1
  11 not used not used
  12 Green illumination?
  13 Red ?
  14 Green ?
  15 Yellow Security signal
  16 Red (LG) Reverse signal
  17 Blue Park Brake signal (Short to 10)
  18 Black (W) Speed signal (add SW)
  19 not used not used
  20 Brown (W-B) SNS2 Microphone
  21 Black CANH TRC VSC
  22 White CANL TRC VSC
  23 Green SWG Steering cont
  24 Blue SW2 Steering cont
  25 LightGreen SW1 Steering cont
  26 not used not used
Edited by Chris.ac
  PIN Colour Name
  1 Yellow +B1
  2 Grey ACC1
  3 Red (B?) IG
  4 B MACC Microphone
  5 W MIN+ Microphone
  6 R MIN- Microphone
  8 - TEST
  9 -
  10 Brown GND1
  13 Red ?
  14 Green ?
No I have the power plug and the speaker signal wires, they work fine, but your chart helps alot. Thanks
We need to get all the original plugs from the wiring looms photographed, and Identified for several loom revisions it seems.
Mine is a may 2010, and I believe the loom swapped in September 2010.
Some of the headunits have that green GVIF connector, which im not sure if it is a digital video feed in for the hybrid, which on the 20series started in late 2010, early 2011 (the GVIF is video only, and can be used to overlay graphics or video feed)
Blue is definitely to do with the 270/360degree cameras, parking assist, sonar overlay (it should connect to the parking assist ecu under passenger seat, but the rear camera is separate feed via another plug.
Brown, im still not 100%, it needs connecting to correctly display video at rear, im thinking part of the DTV input - it may have another ecu it connects to that swaps input between dvd and dtv.
I have a 2012 hybrid and the back of my unit looks like this, apparently - no green port. I think the hybrid info displayed just comes from the canbus, it’s not that detailed.
I've just purchased a wiring harness from Aliexpress with a canbus. I think the one that came with the head unit is just a standard cable and it has no canbus unit. I've spoken to the seller and he has told me the protocol setting I need. I tried them before but made no difference. This cable has an extra plug to go in the back of the unit.
Skyfame Car 16pin Wiring Harness Adapter Canbus Box Decoder For Alphard 20 Android Radio Power Cable - Speaker Line - AliExpress
the difficulty is that all the wiring diagrams I can find, all seem to be from the alphards that were export models, they seems to have different sockets to the domestic alphards.
its bizarre
its bizarre
I didn't even know there was domestic models. I thought all Alphards and Vellfires where imported.
They are.
I think Chris means Domestic, as in Japanese market, and exported, as in all other markets.
5 hours ago, Rojie said:
They are.
correct.
JDM (Japanese domestic market) vs the models specifically created for export.
Toyota started exporting the 20 series, to countries like China, Malaysia, Russia, UAE.
These usually have codes like ggh20L or ggh20R (L= left hand drive R=right hand drive) they usually come with options that comply with local legislation, such as in China, the headlights have auto dip, Russia have rear fog lights, China with have smog detector that turns climate control to internal circulation.
The headunits are usually dumbed down, they don't feature G book, or telematics, or have English/Russian as a selectable language, the 18 speaker option is rarer, as the wiring looms are standardised, as aftermarket systems are usually fitted.
It is why finding JDM versions of the wiring diagrams is hard, these are controlled by a publishing house, in Japan, you are able to buy the maintenance/repair manuals and wiring diagrams on CD ROM and book form as a dealer option.
I found some of these manuals and cd ROMs for the ggh20W ATH20W and ANH20W, but I'm not willing to spend upwards of £300 for the set.
They are out of print, so it's the 2nd hand market only.
Thankfully, the exported versions manuals are available online, and apart from the headunit wiring, everything else seems okay
@arthurj I have the nhba-x62g, which appears to have many of the same connections on the back as yours. Do you have any information on what the different connections
are for please? l've never seen anything like the 4 individually numbered (1-4) single pin black sockets (top right of your photo) before.
As it happens…
I think those 4 are for Japanese TV, either an aerial or decoder box.
24 minutes ago, arthurj said:
As it happens…
You sir, are a legend! That's amazing, thanks so much! Did you keep your head unit or swap it out?
I still have mine, mainly because the kids love watching dvds in the back and it’s great for that.
A lot of connectors shown but none of them appear to be anything like the connectors on the back of my Panasonic 86100-58100 head unit. Most of the connectors are IMG_3702.thumb.JPG.aa249e34419cd000530fad36046ccf16.JPGplain white with a couple of grey ones. It's a late 2011 240 Alphard.IMG_3703.thumb.JPG.91b95f1906ea8d041262e7db95702bc6.JPG
I;m mainly looking to identify the speaker cables and if possible, the steering wheel controls. Everything else I can live without. Id be very grateful if anyone can point me in the right direction.
Many thanks, that will keep me busy for a while 🙂
Hi @Voodoo101, have you managed to find solution for this? I have the same problem. My Android unit cannot read the CAN bus. Hence I'm missing a bunch of good features like parking guideline curving following turning of the steering wheel. Not to mention seeing sensors info through the camera view, and other vehicle settings/infos.
My model is Vellfire 2024 (Petrol model). From my research, the hybrid model (that comes with amplifier) uses CAN bus system but the pure Petrol model doesn't. Hence I'm stuck, the car is working fine with speakers and steering wheels control but I would love to have full access of features and info through CAN bus.
Any help would be appreciated.
Hey Tony.
I ordered a new cable off AliExpress that has a lead that plugs into the OBD reader. I haven't tried it yet cause I am upgrading to a 15 inch head unit. I have Raise canbus decoder which should all work together to give me the extra features.
There is a post on this forum of somebody who tapped into the cables going to the speedo unit, because all the info goes to there aswell, but im not brave enough to do that. If the cable doesnt work, i can just unplug lol
Thanks @Voodoo101
I saw that thread just now!
I feel tapping into speedo unit cable sounds safer because it is 'read only'.
Doing it with OBD will give extra features to change vehicle settings , it could write something to ECU and if not done right, the risk is higher, no?
BTW, upgrading to 15 inches is a huge upgrade and i have not seen anyone done it. Biggest i have seen is 11 inches in attached model1749872321701.png.a3ebe5742e88ab1b229c914191a07a61.png
TonyOh, whats the details on the 15" display? Link to it?
